Some "change not allowed" where changes sure have an effect.
The second value for fw in sport mode being something completely seems to be the biggest news.
Ohh no, I'm really sorry, please un-report me (-;
So, there is a way to actually flash the firmware "from home"? I thought you guys were talking about the parameters file (.ini). Where can I find some info abot that? (It is a year ago I read through the whole thread, so I might have read something I dont remember right now, sorry if it has been brought up before). I will PM you my .ini file. Would appreciate it f you can hav a look and se if there is anything I have missed.Bartosh wrote: ↑Dec 23 2020 3:35pm
I can try to help you after NYE, but this would involve uploading a fw I got = there's a chance it'll blow, ask me how I know it. PM me your ini anyway (save params opt. in the app).
If you think you have a hall-related problem, but your halls seem alright, I'd have a look at the rotor's axle nut and the hall board as well (misaligned? did you change the offset?). Anyway I suspect they did change the fw and just kept the version intact. Though, Em200 fw ver seem older.
So, I got response from QS the other day! A new file with weird values on page 2 (except from the max Amp settings, that was 150A). They confirmed that the FW settings are correct, and i should not touch them. They did not say why they differ completely from what the manual says they should be. They also said max 150A for boost current, but raised it to 180A when I asked them why manual states 250A and their website says 220A. Since I dont want 6000rmp into the gearbox, I used top speed limiter at 70% to limit the speed. However, this also seems to lower max Amp with the same amount, both on boost and busbar current on page 1. Right now my motor seems to run as it should on the settings I have posted in the screenshot, but I dont have any speed limiter in boost, so it spins to 6000 rpm. I have planned to put a Cycle Analyst on this vehicle anyway, so I think I will just wire up boost mode always on and limit speed and throttle curve with that.
Didnt know I could use HDC for that, will try tomorrow, thanks!j bjork wrote: ↑Dec 26 2020 3:34pmYou can use hdc to limit rpm instead, that is how it worked for me at least.
You already have it set to 6000, so I guess you get 6000rpm?
Interesting that they set the flux-wekening to 4000, 6000 and 10000. I think the manual says max 3000.
When you have it up and running I think you should try to raise the flux-wekening compensation and see what happens, especially at low rpm.
What do you mean with boost current, and what do you want to set to 314A?, that is an uneven number.
I have set battery amps to 400, but I only get about 350A
I dont know without looking in the diagrams witch pins it is, but you ground to activate sport mode.
Yes, you are correct.
