I would like to connect both brakes to the CA. Brakes has 3 wires (Ground, 5 volts and EBK). I'm going to tie wires for the ground and EBK together). Can I do the same for the 5 volt wires? If I tie the together will that harm the CA with 10 volts?
Thanks
Thanks
