cycle analist pas settings
ugo   1 µW
Post by ugo » Sep 21 2018 12:46pm
hello I having some difficulty for the configuration of the pas on my ebike i just purchased a "pas_24" from grin tech.
it works. with a good response as soon i start pedaling and stop but the bike goes to the maximun speed and even if i go very slow with the pedaling frequency it keep the maximum speed. in other words as soon the pas detect pedaling it give to max power i couldn't find the way to set it in a way to have a proportional speed.
I'm been trying to change all the parameters without success, please can you tel me what I'm douing wrong?
Killer-B   10 mW
Re: cycle analist pas settings
Post by Killer-B » Sep 24 2018 10:31pm
hi
what settings habe you changed, you need the pole count to be right and your whatts set to shat you like , maybe 200wthen it should be less agressive, If you add the aux swith it makes changing assit levels on the fly so easy.
regards
Josh
everyday commuter is a khs alite 500 with Grin thru axle front hub, phaserunner, battery is 20s5p x2
trail bike is a Norco with qs 205 5t with 120 amp Kelly controller 20s5p
first build rear 1000w Giant with grin 40 amp and 14s8s
newest is custom frame qs205 5t in moto rim and shiko d/p with Kelly 120amp and 20p5s +20s5p
