Adaptto Cable 2 WD
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
mahoma30   100 mW
Adaptto Cable 2 WD
Post by mahoma30 » Oct 05 2019 5:33am
i'm looking for an Adaptto Y- connection cable between master and slave for a 2WD system include BMS and the spezial slave Connector
Y-connector is optional and provided only to those who need to use 2WD set together with BMS
mahoma30   100 mW
Re: Adaptto Cable 2 WD
Post by mahoma30 » Oct 08 2019 3:03am
thats the Answer from Adaptto:
Hello!
On the main controller (master) there is a special 4PIN wire connected to the brain board in a special way.
The secondary (slave) controller is standard, the 2WD function must be enabled in the menu. To communicate with the main controller, data transfer via the BMS connector is used. This is not a CAN bus, and transmission is not via CAN.
The connecting wire for connecting the master controller and connecting the BMS at the same time, this is an ordinary double wire connected in parallel, you can make it yourself, there are two female connectors in parallel connected to one male connector, the main thing is not to confuse the wire numbers according to the diagram.
You can connect the main and secondary controllers directly through the BMS connector.
