Hebb Front Hub Motor 36 volts/350 watts
Looking for a Hebb Front hub motor 36 volts /350 watts
Thanks in advance, Joey
Re: Hebb Front Hub Motor 36 volts/350 watts
https://ebikes.ca/shop/electric-bicycle ... f_l10.html
Not cheap, but it would be way more efficient than the early V1 motor that bike came with.
One advantage with replacing the Ezee w/ another Ezee, is the hub is probably the same and you could swap motor cores w/out breaking down the whl.
It doesn't have to be an Ezee though, something like a Bafang BPM built in a whl. would be less expensive (Avilable @ BMS Battery).
It could be yours could be repaired, I had two early Ezee motors and both had problems w/ the Hall wires becoming disattached from the PCB.
Motomech '11 Motobecane Fathom team, frt. mounted, recycled SWX02 from a Jump rental, 14S (52V nom.) Turnigy LiPoly, PSW Power 9-FET 20A controller. Mean Well HLG-320H-54A, Schwalbe Marathon's, 27 to 28 MPH.
Thank you so much!
I have to talk to my mechanic now!
Cheers, Joey
Cheers, Joey
I've got a few... PM me if you want.
Yes, I'm very interested. How much?
Not much... Like $100 plus shipping maybe?
I have hebb controllers and wiring harness etc also fyi
Cool! Let me call to my Mechanic!!
Can you please send pictures of hebb controllers ,wiring harness and motor connection.
Are these new or used?
757-373-0997
757-373-0997
Sorry for the delay... Holidays.
All used.
All used.
I have move front wheels and controllers seeing in storage I'll get pics of.
I see you're all the way on the other side, so shipping will be a thing..
I'm actually from Norfolk originally.
Voltron,
Just saw this now! Was reaching out to you to send pictures. Thanks so much I don't see your email till now.
Will show my Mechanic. Call I call you? My cell is 757-373-0997 or can you send me your cell number. I will be happy to pay for shipping ! No problem. Thanks so much again, Joey
Can I maybe just buy a whole wheel ?
