lowish wattage controller with regen
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell.
m3vuv   100 W
Post by m3vuv » Aug 30 2022 2:44am
hi all i had a 1kw controller that had regen braking,i swapped it for a 500 watt unit for better range,thing is the new controller has no regen braking option,has anyone a link where i can buy a 500 watt controller that has a regen option,ie ebay etc,TIA.
A-DamW   10 mW
Re: lowish wattage controller with regen
Post by A-DamW » Sep 15 2022 11:31am
What is the max voltage you are looking for?
What kind of vehicle?
The Xiaomi M365 scooter controller is cheap and abundant: https://www.ebay.com/itm/284916660444
Fairly capable, (field oriented control, regen) and you can flash open source firmware if desired:
viewtopic.php?f=30&t=111834
viewtopic.php?f=35&t=114514
You can swap in a higher 100v capacitor, and change the voltage divider resistors for higher voltage operation.
just to name a few,
Also, the Flipsky 75100 is an option.
Been lurkin' since 2008
m3vuv   100 W
Post by m3vuv » Sep 15 2022 3:05pm
its for my ebike and 13s 48v.
