Broken Cycle Analyst(s)
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
Postby Rollodo » Fri Aug 09, 2013 11:32 am
If anyone has a CA that:
- Only shows a limited number of information;
- With not clearly visible numbers or letters;
- Is not good for everyday use, but with the cords intact (or if the cords are damaged, that's cool, too);
- That you would otherwise throw out.
You get the idea.
Please let me know.
Please fill out your location - it takes seconds and saves hours.
Please review your grammar before clicking the Submit button.
For Sale: Catalyst Components R1.
Wanted: Broken/Damaged Cycle Analyst(s)
Rollodo
Re: Broken Cycle Analyst(s)
Postby Rollodo » Fri Dec 20, 2013 8:53 am
Just let me know if someone has one or two. I can't say that I'll pay top dollar (since it's for non-functional / broken), but let me know what you have. Thanks again.
Rollodo
Postby Farfle » Fri Dec 20, 2013 11:24 am
Do you just need the cords? If so, we have half a dozen cords and plugs from various versions.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 420A at 87v
Peak power out: 34 Hp and 105ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby Rollodo » Fri Dec 20, 2013 11:30 am
Farfle wrote:Do you just need the cords? If so, we have half a dozen cords and plugs from various versions.
Nope, need the whole thing, in fact you can keep the cords. I just need the unit to display something, to know that once I plug the power, that it will at least be registered, but not necessarily show everything legibly. Think of it this way - if something isn't showing properly for whatever reason after a number of tries, you'd probably think the thing is broken. If yes, consider sending it my way.
Rollodo
Postby wineboyrider » Fri Dec 27, 2013 10:04 am
I have one that doesn't display anything. CA v2?
wineboyrider
Postby Rollodo » Fri Dec 27, 2013 10:25 am
wineboyrider wrote:I have one that doesn't display anything. CA v2?
Nothing at all? Not even a single pixel on the LCD? PM me the price shipped (probably USPS, as it's most economical), let me see, maybe it'll still serve my project well.
Rollodo
Postby Rollodo » Tue Mar 18, 2014 9:06 am
This is still in effect.
Rollodo
Postby Rollodo » Fri Jun 20, 2014 9:14 am
Just updating, still looking for a decent deal.
Rollodo
Postby Rollodo » Thu Sep 18, 2014 7:11 pm
Still looking, let me know what you have.
Rollodo
Postby adit2urpan » Sat Sep 27, 2014 12:23 pm
I have one all cords intact it powers on but keeps cycling thru the different screens or info displays one right after the other and none of the buttons do anything when I press them.... located in phoenix, az
like to thank all who provide this wealth of info... I've learned more here than most any place I visit online.. Thanks!
adit2urpan
1 W
1 W
Postby Rollodo » Sat Sep 27, 2014 5:06 pm
adit2urpan wrote:I have one all cords intact it powers on but keeps cycling thru the different screens or info displays one right after the other and none of the buttons do anything when I press them.... located in phoenix, az
Ok, PM me.
Rollodo
Postby adit2urpan » Sun Sep 28, 2014 10:43 pm
pm'd you let me know if you want it as I'm going to end up tossing it... like I said it displays and turs in just cycles over and over... I don't want anything for it I'll even be nice and ship it free if you can use it for your project whatever it may be
adit2urpan
1 W
1 W
Postby voicecoils » Mon Sep 29, 2014 12:14 am
adit2urpan wrote:pm'd you let me know if you want it as I'm going to end up tossing it... like I said it displays and turs in just cycles over and over... I don't want anything for it I'll even be nice and ship it free if you can use it for your project whatever it may be
Just FYI:
GRIN Products
We offer a full 3 year warranty and lifetime support on most of the components that we manufacture ourselves, including the Cycle Analyst...
http://www.ebikes.ca/shop/support/warranty.html
Grin will fix your CA if you want them to 8)
voicecoils
Postby adit2urpan » Mon Sep 29, 2014 12:43 am
ohh wow!! thanks! Yeah I bought it bak about 6 or 8 mnths ago from goldnmotor canada and it stopped working 3mo ago and never thought to check warranty as I've had experiences elsewhere that shldnt but I allow to cause me to not even really attempt to try warranties when something goes on the fritz.. going to check that button and if not check out and see what they have to say, can't hurt huh!
adit2urpan
1 W
1 W
Postby Rollodo » Mon Sep 29, 2014 8:39 am
I replied to your PM (attached). The combination of the highlighted area on both left and right indicates that you've both received and read it at that time.
(157.89 KiB) Downloaded 2 times
Rollodo
Postby Rollodo » Sat Mar 28, 2015 9:16 am
Bump, just let me know what you have. Can't pay much, but if you'd be throwing it out anyway...
Rollodo
Postby Rollodo » Sat Aug 01, 2015 2:54 pm
Still active, still looking.
Rollodo
Postby vrod » Thu Sep 17, 2015 2:02 pm
Rollodo,
let me look into my shop and see what I have.
I know that I have 1 completly functional CA. It is an older series with the large screen format (comes with a shunt too). I used it on my electric trike and had the speedo hooked up.
I have another 1 or even 2 units that am not sure if they are still functional. Pretty sure 1 is a large screen just like the one mentioned above. Of these, I remember snipping off the speedo wiring, as I used this on a battery. If I remember correctly, I think the CA was not happy that this was a 12v battery and stopped working.
I'll sell the working unit for $40. If the other(s) are non-functional, I'll throw them in too. As well as the shunts and magnetic pickups.
-Vic
vrod_2000@rocketmail.com
vrod
Postby steveo » Tue Nov 03, 2015 1:45 pm
Rollodo wrote:Still active, still looking.
I have one that works but i think it doesn't read speed.. I'd have to recheck
is a large display v2.23 i think direct plug in.. .. :wink:
let me know
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
steveo
Return to Items Wanted
Who is online
Users browsing this forum: No registered users and 2 guests
