Looking for 72 volt LI-ION/18650 charger
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
rumme   100 kW
Post by rumme » Oct 28 2017 4:02pm
I currently have a 3 amp charger but wanted a fast charger . Can be new or used, as long as it works properly. Let me know your asking price and the charge rate in amp hours. Ty
amberwolf   100 GW
Re: Looking for 72 volt LI-ION/18650 charger
Post by amberwolf » Oct 29 2017 1:25am
Charge rates are in amps, not amp hours.
Amp hours are only a capacity measurement of a battery (or a measurement of power usage).
Also note that before you get a new charger you need to determine the max safe charge rate of your cells/pack, and be sure the new charger will not exceed that rate. Cell damage can occur, either slowly over time or quickly from overheating, depending on how far past the current limit you are charging it.
If you have a BMS on the pack, you also have to not exceed the BMS's max charge rate, or you can damage the BMS's input FETs.
rumme   100 kW
Post by rumme » Oct 29 2017 11:47am
amberwolf wrote:Charge rates are in amps, not amp hours.
Thanks for the info.
