BMS without cell monitoring
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
DVDRW
Post by DVDRW » Mar 10, 2018 12:15 am
Is there any compact BMS that does not have cell level monitoring? Need only monitoring entire pack voltage and LVC/HVC protection.
Quality new 18650 never get out of balance (over 2 years already). Cheap cell level BMS-es tends to be Battery Murdering System.
If cells not connected it cant be bad for battery.
I expect it to be same price or cheaper than cheapest cell level BMS-es.
Im running not programmable 250W 36v ebike controller @48v so no LVC by controller
amberwolf
Re: BMS without cell monitoring
Post by amberwolf » Mar 10, 2018 3:36 am
Some thoughts:
From what I can tell, many (maybe most) of the BMS that do have cell level monitoring don't actually check if there's cells connected or not--if the voltage of a cell is low enough, or a sense wire is broken off a cell group, it doesn't trigger the BMS (poor design).
If one of those BMS also has a whole-pack HVC/LVC (many probably don't), you could use it as a pack-only BMS, never connecting the sense wires.
I don't have any lists of which ones do which functions, though. :(
If you're running a Cycle Analyst, you can set it's LVC to decrease throttle (or disable it) below the LVC point. It doesn't have an HVC, though. :/
