Meanwell S-350-24 or 48 volt DC power supply
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
dozentrio   1 kW
Post by dozentrio » Apr 13 2018 1:53pm
I need to replace my Meanwell bulk charger and can't find any good sources for the old easy to mod (R33 mod) DC power supplies. Anyone have any of these or know a source?
fechter   100 GW
Re: Meanwell S-350-24 or 48 volt DC power supply
Post by fechter » Apr 13 2018 2:30pm
There are several other models we have the modification data for.
Search for a S-400-48
or
T-400-48
or
AD448.3-400W
No guarantee the ones you get today will be the exact same layout as the older ones, even if the model number matches. In most cases, I can tell from a picture of the board where the "R33 equivalent" is.
amberwolf   100 GW
Post by amberwolf » Apr 14 2018 3:17am
What do you want the PSU to do, for adjustments? If you just need to adjust volts and current limit, theres at least two series of MW that do this with built-in controls, like the HLG-xxxH-xxA versions, so you dont have to mod them. Theyre also potted and sealed, so no fans needed and are weatherproof and can handle the vibrations if you need to carry them on the bike.
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Apr 20 2018 11:50am
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
