Page 1 of 1
A2B Metro - [rear rack, auxiliary, secondary, battery]
Posted: Mar 08 2019 5:25pm
by marty
Want a auxiliary battery that mounts to the rear rack on A2B Metro Electric Bicycle.
Sent a email to people at http://wearea2b.com/index.php/us Reply was:
Replacement batteries for the Metro are no longer available through A2B.
The main battery is inside the frame.
Re: A2B Metro - [rear rack, auxiliary battery]
Posted: Mar 14 2019 11:41am
by E-Glider
Yes, 'wearea2b' seem very quiet now! I guess you could also try these guys:
https://ebikemarketplace.com/blogs/news ... eplacement
They may already have a complete spare/reconditioned rear case/pack available for you?
There was also one on eBay a year ago - maybe contact the seller to see if he can point you in the right direction anyway:
https://www.ebay.com/itm/A2B-Metro-Velo ... _cvip=true
There was also a place in Taiwan offering new rear packs last year, but they seem to have disappeared now!
Good luck anyway.
Posted: Mar 16 2019 6:02am
by marty
E-Glider,
Thanks for finding that eBay add. Now I got pictures of what I am looking for.
Re: A2B Metro - [rear rack, auxiliary, secondary, battery]
Posted: Mar 16 2019 6:53am
by marty
More pictures.
Posted: Mar 16 2019 8:10am
by marty
eBay > Click on the ♥ heart sign when searching.
My eBay > Saved searches, Search for a2b metro battery
Now eBay will send me a email whenever someone is selling a a2b metro battery.
Posted: Mar 16 2019 2:46pm
by E-Glider
Marty,
Cool.. no worries!
Maybe drop these guys a line too:
https://ebikemarketplace.com/products/a ... -batteries
They may well have a 'spare' rear case/pack already in stock?
Posted: Mar 16 2019 3:21pm
by marty
E-Glider wrote:
Mar 16 2019 2:46pm
Marty,
Cool.. no worries!
Did ↑
Also added a2b velociti battery to my eBay Saved Searches.
Posted: Mar 16 2019 3:29pm
by fechter
You can use just about any 36V battery for the rear. You just need to make a way to mount it and cut off the stock connector and splice on a new one that fits the new pack.
You can also run a higher voltage up to 48V for more speed.
The factory rear pack is nice but very hard to find these days.
Posted: Mar 17 2019 6:27am
by E-Glider
Yep! ;/ (@ 'fechter' - your posts/work here have inspired me greatly - thank you!)
Luckily my old Metro already came with a factory rear case, which I then 're-packed' with x4 of these - in series/parallel:
https://hobbyking.com/en_us/zippy-compa ... tore=en_us
Frame pack now has x4 of these in similar config:
https://hobbyking.com/en_us/turnigy-hig ... -xt90.html
Tight fit, but worth it. :)
R
ear also runs lights & USB charging port. ;)
Good range & pace now - Stock motor loves it, but stock controller has the thermo cut-out glitch still on those hot days!
Posted: Mar 21 2019 6:10am
by marty
Some random numbers to help others who might be searching the internet for this battery.
SDTDCGC400149
SDTDCGD160387
36V/13.2A
Lithium
UM1006F
TD HiTech
63103 00 40010
Posted: Mar 26 2020 7:38pm
by kauaikit
Hey e-Glider.....the lithium batteries you linked to are either 7sx2 =14s (51.8v) or 6sx2=12s (44.4v)! Neither of these packs will work with the stock A2B 36v controller, right?
Posted: Mar 27 2020 4:29pm
by E-Glider
kauaikit wrote:
Mar 26 2020 7:38pm
Wrong. Both packs still work fine on my Gen 1 unit. :)
It seems that the stock contoller will handle up to around 57-59v before it freaks/burns out!
As mentioned, the only 'glitch' with the stock controller/motor seems to be the built-in automatic thermo cut-out.. which obviously, ambient temperatures aside, will tend to get warmer sooner, the higher the operating voltages etc.
Posted: Jun 30 2020 1:29am
by kauaikit
Great.....I asked as I've got a '10 A2B Velociti that is in need of a battery rebuilt & I desired more top-end speed over the 20mph limit. Is it possible to cut a "wire" for the temp shut-off? So, what level speeds are you getting with a 14s pack?
KB
Posted: Jun 30 2020 2:05pm
by fechter
The thermal sensor is buried in the controller, so not easy to get to. The controller is potted.
With the stock 36v battery, my Metro would go about 20mph. With a 14s battery, it goes around 27mph. The only time I had the temp sensor cut off on me was after a really long ride. It takes about 30 minutes to cool off enough to reset.
