26 2011 Nissan Leaf modules for sale. Canada only
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
ecat
Post by ecat » May 10, 2017 11:10 pm
SOLD! I have 26 of these modules left from the original 48 that come in a full Nissan Leaf lithium battery pack. 100.00 each plus tax and shipping
These are out of a 2011 Leaf with 40,000 km on the odometer.
Each module is 2 cells in series, 2 in parallel. They are 50 amp hours 7.6 volts, 380 watt hours each.
MODULE SPECIFICATIONS
Number of cells 4
Construction 2 in-series pairs in parallel
Length 11.9291″ (303 mm)
Width 8.7795″ (223 mm)
Thickness 1.3779″ (35 mm)
Weight 8.1571 lbs (3.7 kgs)
Output terminal M6 nut
Voltage sensing terminal M4 nut
Module fixing hole diameter 0.3582″ (9.1 mm)
CELL SPECIFICATIONS
Cell type Laminate type
Cathode material LiMn2O4 with LiNiO2
Anode material Graphite
Can be stacked in series and or parallel for higher voltage or more capacity.
Good for EV projects like motorcycles, scooters, boats, and solar storage or power walls.
I used 14 cells to make a 48 volt (7 modules in series) 100 amp hour (2 modules in parallel) battery for a solar powered off grid cabin. The battery is nominally 4.8 kW/h of storage, and required 14 modules. See pictures.
2007 Catrike Expedition, dual Grin Through axle hubs, Dual PhaseRunners, 72V V 20 AH samsung 25R CA3
Edgerunner W Nuvinci hub, Patterson overdrive, Stokemonkey mid-drive. Expedition 19.8 AH Sony V3
Bike hauling trailer with two NC M3007RC hub motors on 20" wheels, two Grin 25A cont, CA3, Prius Plug-in 52V 17 AH
I am an official Grin Tech and Expedition Battery dealer on Salt Spring Island, BC Canada.
***Now the official Canadian wholesale distributor for Juiced Bikes***
http://juicedriders.ca/
spuzzete
Re: 26 2011 Nissan Leaf modules for sale. Canada only
Post by spuzzete » May 11, 2017 8:26 am
Hello,
I am assuming that is Canadian dollars and not US?
Cheers!
8)
ecat
Post by ecat » May 11, 2017 5:06 pm
Yes, Canadian dollars :D
52 volt 100ah battery made from these cells:
spuzzete
Post by spuzzete » May 19, 2017 8:41 pm
Hi,
I might be interested in 7-10 modules for a project. How much is tax and shipping to Calgary, AB?
Also, did you test the modules and how did they perform?
Cheers,
8)
