20s15p Sony Konion pack for sale
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
litespeed   100 kW
Post by litespeed » Aug 12 2018 4:36pm
So I built this a couple years ago. Works great but I just built a 45amp 30Q pack and don’t need a second for back up.
The good,
I bought a bunch of Makita 18 volt packs from Doctorbass and pulled them apart. I went though all the cells, pulled the good and pitched the bad. Built using .2mm nickel and a CD spot welder I built myself. This is a hot off the charger 84volt 22.5 amp pack. Was used mainly on my Vector frame with MaxE and QS 205 3.5T motor. I have the charge set to a max of 4.1 volts and weekly I get about 50 miles average out of the pack. I routinely suck 200 amps out of the pack but only 15 to 20 seconds as I’m breaking most posted speeds by then. I originally built a 24s15p pack (3-8s15p packs) but dropped to 20s (2-8s15p and 1-4s15p) when I got my MaxE. I used all the cells on 1 row for a couple replacements and fixing my wife’s cordless vacuume. All wiring is 12gauge With this sale I’m including an extra 3s15p built, 11 loose cells, about 7 feet of the .2mm nickel and the harness I built to series connect all packs together using EC5 and one XT90-S for spark control. I kept the breaker to use on my new pack. They are wrapped in foam sheets and then wrapped with duct tape. I originally used coreboard but they were too wide.
The not so good,
When I built the pack I bought all the nickel from one of the electric bike supply shops and found out afterwards that it was nickel plated steel. Works fine but not what I entended to use. I just didn’t know until after I had spot welded it. I’ve had a couple cells die in the pack. I had to remove a couple about a year ago and all was good again. It appears I have another bad cell or two. I have one p in the 4s pack that runs about .13 volts lower than the rest of the pack. The price I’m put is as is. If someone wants to pay me an additional $125 I’ll find the bad cell(s) and replace them.
As I stated I regularly ride 40 to 50 miles at a time and 90% peddle which is pretty good. Only a couple times have a ridden aggressively and used the pack up in 25 to 30 miles throttle only. You could use this as a 16s pack for one of the mid drive set ups and is ready to go. When I originally built them I was using my R/C chargers and installed 8s balance taps. I built an adaptor to change them over to 4s for the MaxE and all comes with the sale.
I would prefer a local pickup but will ship at buyers expense because it’s probably going to be costly.
I’d say there are thousands of miles left in these batteries whether you baby them or ride them hard, Koinions are known to be very robust cells, I just wanted to build a new pack.
Located in St. Louis (St. Charles) Missouri $200 out the door. Pictures will have to come though email. My iPad no longer has a working program to shrink pictures. PM me for email address.
Tom
litespeed   100 kW
Re: 20s15p Sony Konion pack for sale
Post by litespeed » Aug 13 2018 11:02am
Found an app that reduces pictures.......On price I will take best offer.
All that’s included.
wye   1 mW
Post by wye » Aug 14 2018 9:06am
Pm sent
One of the new things people began to find out in the last century was that thoughts--just mere thoughts--are as powerful as electric batteries--as good for one as sunlight is, or as bad for one as poison. To let a sad thought or a bad one get into your mind is as dangerous as letting a scarlet fever germ get into your body. If you let it stay there after it has got in you may never get over it as long as you live.
Frances Hodgson Burnett, The Secret Garden
krombopulos_michael   1 mW
Post by krombopulos_michael » Aug 15 2018 11:48pm
can you ship to virginia?
litespeed   100 kW
Post by litespeed » Aug 16 2018 6:38am
If you absorb the cost. I have a few looking so I think I’m going to replace the bad cells. That way it’s ready to go for whomever buys it.
Tom
steven7601   10 W
Post by steven7601 » Aug 16 2018 11:09am
I want the pack just let me know the cost to ship it to 5416 Dimond Ridge Rd. Nunnlley TN. 37137
litespeed   100 kW
Post by litespeed » Aug 16 2018 11:32am
I’ll price it out tonight to ship it legally.
Tom
litespeed   100 kW
Post by litespeed » Aug 27 2018 5:47pm
Battery is sold....sorry forgot to mark it sold.
Tom
