Garage Sale: Dune Buggy, BMC, x5403, Fairing, Moped Motor Mount, MORE
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
oatnet   10 MW
Post by oatnet » Nov 18 2019 2:58pm
Keep checking back, I'm freeing up storage, I'll be adding pictures of more treasures I find!
-BMC Motor laced to Alex DX-32 rim -- $150
-Motobecane Moped Motor mount for Etek/mars -- $75
-ZZipper model ZZ-ATB06 Mountain bike fairing -- $125
-"Farfle" heavy-duty rear swing-arm for the Genesis v2100 -- $165
-SKS Chainguard --$10
-FAST Street-Legal Electric Dune Buggy -- $9k
-Fox DHX RC4 Shock -- SOLD
-Disk and Side Cover for Crystalyte 53xx -- SOLD
-Shimano Acera MD-390 deralliur SOLD
-X10 Home Automation (lot) SOLD
-Dewalt/a123 packs -- FREE SOLD
-*MINT* Crystalyte x5403 Wheelset SOLD
Domestic USA only, buyer pays shipping/paypal, Local Pickup available.
$150 I sent this motor to Ilia of ebikes_sf to repair phase wires I melted during extreme hill testing, and to be laced into a durable Alex DX-32 rim. I finished the build with a different BMC motor and set this one aside as a "backup" after Ilia repaired it. It's been in the box ever since, so I believe it works but cannot verify it. The motor/clutch had <10 miles on it at the time of the repair, and the fresh relace is beautiful.
Comes with (2) FREE BMC-specific controllers - first an original BMC 50a controller that stopped working after I installed (miswired?) a cycleanalyst connector - the good news is no smoke, just no throttle. Second is a Kelly controller that worked, but I remember being disappointed with it for some reason.
$75 Motebecane Moped motor mount for an eTek/MARS and asst parts. I bought this from user "northernmike" when he parted out his fast "Electrobecane" (1973 Motobecane 40T) build. It includes 4 pullys, drivebelt, drivechain, motorcycle sized brake levers (one with cutoff sensor) and assorted parts/brake cables.
Here is one of his posts with it in action:
https://endless-sphere.com/forums/viewtopic.php?t=11442
$125 This is a ZZipper fairing (including EZ handlebar mounting system) for mountain bikes. It extends range by reducing drag, plus reduces eye hazards like blown sand or tearing up from wind. Everything is unused, unopened, and still sealed in the factory packaging. Zzipper charges almost $300 after tax and shipping. Here is a link to the manufacturer:
https://www.zzipper.com/Products/prod_upright.php
$165 This is a genuine Farfle swing arm replacement for Genesis v2100 walmart bikeframe, new and still wrapped in the original shipping film. This one lets you put a heavy-duty motor on an inexpensive suspension frame without torque arms. When Farfle stopped making these others copied it, but this is the original durable design.
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
oatnet   10 MW
Re: Oatnet Garage Sale
Post by oatnet » Nov 18 2019 3:08pm
$10 New SKS Chainboard - 199mm up to 48t version chain guard. Protect yourself from your bike chain with this Easy-to-install chainguard. $10
$9,000obo The Electric towdster is now for sale! It currently registered/insured in California as a 1970 SPCNS "special construction" title. It has a ball joint front end with Disk Brakes, and an IRS rear with drum brakes. The front wheels have unique custom fenders, and it has custom low mounts for the original taillights. Here is the build thread/blog:
https://endless-sphere.com/forums/viewtopic.php?t=50717
The ADC FB1-4001a series electric motor puts a ridiculous amount of torque into a 1,000lb Towdster (it is intended for a 3,500lb vehicle). It can do burnouts off the line in any gear, and while rolling you can break the tires loose with a stomp of the throttle. So much torque, it took a KEP Stage 3 pressure plate to stop burning clutches.
The acceleration at 900amps was too violent for me so I dialed it down to a streetable 400amps, but crazy power is just the turn of a digital dial away. Comes with an 8+kw a123 LiFePO4 battery pack (42s3p 20ah Prisimatic cells) from (3) a123 Factory modules (a 28s3p and two 7s3p). Has a Zilla Z2K 2,000a controller like the one used in the "White Zombie" drag datsun.
In an extreme-duty range test (basically stopsign to stopsign with hard launches) the battery pack was good for 25 miles. More conservative driving with less stops should yield 50-75 miles. I mostly drive it to the beach and plug it in when I get home.
To reduce the number tire kickers, test rides are given to buyers who are serious enough to bring cash.
Image大鸡巴 Motors
999zip999   100 GW
Re: Garage Sale: Dune Buggy, BMC, x5403, Fairing, Moped Motor Mount, MORE
Post by 999zip999 » Nov 18 2019 7:14pm
I will take the batteries Please as I'm big fan of A123 I have four voltpheaked from the Day.
SlowCo   100 kW
Post by SlowCo » Nov 19 2019 8:56am
That buggy is sooo cool! Wider grippier rear tires on it then dial in the 900 amps again and wheelies galore :twisted:
oatnet   10 MW
Post by oatnet » Nov 20 2019 10:32am
SlowCo wrote:
Nov 19 2019 8:56am
Thanks SloCo!
-JD
Image大鸡巴 Motors
alex12342011   100 W
Post by alex12342011 » Nov 26 2019 1:34pm
Do you still have the batteries? I'm interested if they don't get picked up.
100V 9C 2806 Tidalforce 750
100V Cromotor V3 Greyborg
1050hp FF91 "G2-18" Prototype
Trackman417   10 kW
Post by Trackman417 » Jan 04 2020 4:49pm
Dibs on the x5403 with matching rims :bigthumb: :bigthumb: :bigthumb:
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
alex12342011   100 W
Post by alex12342011 » Jan 08 2020 2:03pm
Sent you a PM :)
oatnet   10 MW
Post by oatnet » Jan 17 2020 5:40pm
Still a few things left bump!
Image大鸡巴 Motors
