QS 205 build partout
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
SaabGuy   10 mW
Post by SaabGuy » Jan 09 2021 11:47am
All this stuff has approx 40 miles on it (a few charge cycles). Like new. Located in the USA.
-($80 +ship) shimano hydraulic brakes (no integrated ebrake regen switch on these)
-$50/$100 Torque arms see later post. viewtopic.php?f=9&t=109935&p=1614400#p1614400
(Sold)-($150+ ship) sabvoton 72150
(Sold)-($40ea +ship) multistar lipo 4s 10Ah (8qty)
(Sold)-($500+ship) QS 205 V3 50H 8.33kv with statorade and hub sinks.
ropower86   10 W
Re: QS build partout
Post by ropower86 » Jan 12 2021 7:03pm
Which part of the US are you located in? I am very interested in buying a 4s battery
SaabGuy   10 mW
Post by SaabGuy » Jan 12 2021 7:14pm
Zip 57078
ropower86   10 W
Post by ropower86 » Jan 12 2021 7:32pm
How much for the shipping to 89031? What service are you going to use? Also, why did you gave up on this nice project?
ropower86   10 W
Post by ropower86 » Jan 12 2021 7:34pm
Just want to buy (1 )4s battery. Maybe later this month I might be ending up buying the hub wheel.
SaabGuy   10 mW
Post by SaabGuy » Jan 13 2021 9:08am
Shipping would be $12 for one battery
I dont like the bicycle frame. I want to get a small dual sport bike and build one of those. I also dont like how easy these are to steal... Makes me nervous actually using it.
Blacksword   10 mW
Post by Blacksword » Jan 13 2021 7:14pm
Is that mounted in a 26" fat bike tire what is the dropout width.
Asking as I have an old Ice Cream Truck fat bike with 190mm rear dropout I want to put a QS 205 into.
SaabGuy   10 mW
Post by SaabGuy » Jan 13 2021 7:48pm
Yes. 26x4 80mm rim.
It's meant for 150mm dropouts, but my machined torque plates are 10mm wide to space it out for my 170mm frame. You could probably make it work, but you'd have to forgo the axle nut, but that'd be fine with these clamps though I think.
Ropower86,
Idk if I want to sell just one battery. I'll let you know
ropower86   10 W
Post by ropower86 » Jan 14 2021 11:27pm
SaabGuy wrote:
Jan 13 2021 7:48pm
Yes. 26x4 80mm rim.
Ropower86,
I Will buy 2 battery is that fine with you?
e-biker   100 W
Post by e-biker » Jan 15 2021 5:48pm
i will take all the 4s batteries
24 s 4P, lyen 18 fet,QS 205V3, double crown monster ft forks large steel currie mongoose 24 450 (- the currie ) frame dual hyd disc daily commuter.
24s 20" M/P 2 casted wheelie machine, everybody should have one!!
e-biker   100 W
Post by e-biker » Jan 16 2021 9:00pm
Funds sent for the 4s batteries
johnnyddn   1 mW
Post by johnnyddn » Jan 17 2021 8:40pm
Do you know if the Sabvoton 72150 is the old version or V2? Does it have the bluetooth adapter?
SaabGuy   10 mW
Post by SaabGuy » Jan 18 2021 12:09am
johnnyddn wrote:
Jan 17 2021 8:40pm
I don't know. Picture attached of controller. I have the Bluetooth module.
mannydantyla   10 W
Post by mannydantyla » Jan 19 2021 8:23pm
do you have a contactor, charger, cycle analyst, or anything like that?
SaabGuy   10 mW
Post by SaabGuy » Jan 19 2021 10:36pm
Not for sale, no.
I ended up using a battery master disconnect switch for my main switch... Not worth selling.
Ebuilt   10 W
Post by Ebuilt » Jan 21 2021 12:45pm
Pm sent
:bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt: :bolt:
e-biker   100 W
Post by e-biker » Jan 21 2021 6:02pm
batteries received on time and in great condition.
SaabGuy   10 mW
Re: QS 205 build partout
Post by SaabGuy » Jan 26 2021 10:08pm
I stripped the rim off the 205 hub so I can replace the old hub and sell the frame... Gotta find those old spokes though :shock:
Just selling the 205 if anyone was thinking about getting the whole thing.
SaabGuy   10 mW
Post by SaabGuy » Jan 27 2021 7:20pm
Here are the torque arms if anyone is interested. These are 10mm wide and were used to convert my 150mm dropout motor to a 170mm frame. Two of these (aka two sets of top and bottom halves) could be used on a 150mm frame. One set has M8 threads, the other a M8 through hole for attaching to the frame. One has a larger notch for the 205 50h shaft on the sprocket side. Two m6 bolts in each clamp over the shaft.
Custom machined. Zinc plated (grey stuff is antisieze)
$50 for two. $100 for all of them.
More pics in my build thread
e-biker   100 W
Post by e-biker » Jan 28 2021 9:10pm
interested in one?
SaabGuy   10 mW
Post by SaabGuy » Jan 28 2021 9:14pm
Hmm?
