[EU] [420€] QS205 v3i eBike
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
c.wagner   1 mW
Post by c.wagner » Mar 28 2021 2:00pm
Selling my basically brand new QS205 v3i "eBike" variant.
I needed the "eScooter" variant so that was an incorrect order.
The motor comes with statorade (ferrofluid), added by the manufacturer itself.
Specs:
- QS205 V3i
- 11.3 Kv
- 6mm² phase cables
- dual Hall sensor
- dual Temp sensor
Price new was 455€ plus ca. 20% import cost, is 540€
Shipping inside EU and UK.
If you need any measurements or information regarding the motor or your project, feel free to ask :)
I can also provide you with a set of hubsink v2 cooling fins which lets you push >20kW peak without any heating issues.
Fastjelle   100 µW
100 µW
Re: [EU] [475€] QS205 v3i eBike
Post by Fastjelle » Apr 08 2021 1:47pm
My stealth bomber has 170mm dropouts ....
This is 150mm dropouts ? Can I add spacers or ?
c.wagner   1 mW
Post by c.wagner » Apr 09 2021 4:54pm
This is 150mm dropout min and 220mm dropout max.
Sure, you can either use spacers (or metrical nut) or maybe your swingarm is flexible enough to "bend" the 2cm :D
c.wagner   1 mW
Re: [EU] [420€] QS205 v3i eBike
Post by c.wagner » Apr 11 2021 7:20am
[Update] changed price
Fastjelle   100 µW
100 µW
Post by Fastjelle » Apr 14 2021 4:09pm
Ok thank you
Is it a 4T or a ??
c.wagner   1 mW
Post by c.wagner » Apr 15 2021 3:36am
Fastjelle wrote:
Apr 14 2021 4:09pm
Is it a 4T or a ??
It is a 4T, yes :D
Fastjelle   100 µW
100 µW
Post by Fastjelle » Apr 15 2021 8:18am
OK nice!
DO you have a wheel that comes with it ?
SO its allreay spoked ?
c.wagner   1 mW
Post by c.wagner » Apr 15 2021 11:57am
Unfortunately no, it´s just the motor with statorade (the rim is still in use, I just changed motor because I bought the wrong one).
But if you need an additional heatsink (hubsink v2), I can help you out.
