adapt2entropy
- Joined
- Oct 20, 2013
- Messages
- 16
e-drive system removed from trike (less batteries and prop) $ 2900 Cdn
charger, 75-5 motor, motor mount, sevcon4 controller, contactor, fuse, emerg shut off, CA display, throttle, reduction unit, all wire and cable connections as installed plug and re-play!
66 inch 3 blade ground adjustable prop used for testing provided 200 lbs static, but minimal ground clearance it would have to be shortened or kept on asphalt $ 200
2013 batteries, free if you can organize transport, 2 x 116v batteries delivered 95% of rated capacity 6 months ago, 47 Ahr to auto shut-down in ground testing
shoulder injury makes trike flying iffy and too many projects tells me let this one go, the reduction unit almost cost as much as the asking price; the electric side of the system was assembled by an expert so any questions can't go too deep in the technical details
