LIQUIDATION SALE! UNUSED 48V 10.5Ah 30A battery pack - $65
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
Ellectrico   100 mW
Post by Ellectrico » Aug 06 2021 7:12pm
LIQUIDATION SALE!
Li-Ion Battery Pack 48V 10.5Ah 30A 13s3p, 500w output
Hello everyone! I'm liquidating a micro-mobility oriented company and they have lots of great deals on Li-Ion stuff.
In this listing I'm selling UNUSED 48v 10.5ah battery packs made with the Panasonic-Sanyo 18650 3450mAh cell. The cells typically test 95% and higher due to being kept in storage and balanced at all times. The packs were kept in storage and topped off every 6 months to 50-60% capacity to prevent the cells from deteriorating.
The packs come without a connector but with positive and negative leads for both charge and discharge.
Custom connector soldering available upon request.
Here are the specifications:
DOES NOT COME WITH A CHARGER
Condition:
Weight: 5lb
Cell Layout: 13 series 3 parallel
Measurements: Lenght: 15.5 Width: 2.7” Height: 1.5”
Nominal Voltage: 46.8V (Max voltage 52v)
Limited Charging Voltage: 54.6V/3A
Resistance (23 ± 2 ℃): ≤ 250mΩ
Charging time: 4-5 hours
Cycle life: ~800-1000 cycles
Nominal Capacity: 10.5Ah
Watt Hours: 491.4Wh
Minimum wattage output: 500w
Amount of cells: 39
Cell manufacturer: Panasonic-Sanyo
Cell Size: 18650
Cell model: Panasonic-Sanyo NCR18650GA 3450mAh
BMS: Installed (Low Voltage, Overcharge, Temperature, Current output and Short Circuit protection, with power equalization output)
Storage conditions: -15 ~ +35 ℃, relative humidity: 45-75%, atmospheric pressure: 86-106KPa
Use the operating temperature: Discharge: 0-60 ℃; Charging: 0-45 ℃;
Additional items that might interest you:
48v 13s 30A BMS (comes with wire harness) -$12
Fielect 2x10 Cell holders - $1.5 a piece. (Series Mode: Two rows of 10 cells, 18650 Lithium Battery; Hole Spacing: 19mm; Hole Dia: 18.5mm, Material: ABS; Color: Black, Has room for nickel strips)
Also there is a variety of Electric Scooter Hub motors available, details on request.
Custom made battery packs are also available. Message me for a quote.
IMG_6937 (2).jpeg (79.12 KiB) Viewed 1900 times
IMG_6938 (2).jpeg (129.18 KiB) Viewed 1900 times
no wrap.jpg (173.16 KiB) Viewed 1900 times
s-l1600 (2).jpg (165.53 KiB) Viewed 1900 times
s-l1600 (3).jpg (101.57 KiB) Viewed 1900 times
s-l1600 (5).jpg (110.1 KiB) Viewed 1900 times
stevestollman   1 µW
Re: LIQUIDATION SALE! UNUSED 48V 10.5Ah 30A battery pack - $65
Post by stevestollman » Aug 06 2021 7:32pm
Size of the motors? Where are you? Can UPS?
Steve
999zip999   100 GW
Post by 999zip999 » Aug 06 2021 8:53pm
Hub motors laced or unlaced ?
Stu Summer   100 W
Post by Stu Summer » Aug 07 2021 7:06pm
I'm interested in a couple of batteries and the hub motors. How do you ship, how do you want payment, and need photos of the hub motors.
2013 DB Haanjo Commuter with BBSHD and Zzipper fairing
Marin Rift Zone FS with BBSHD
Kysmo "lab" bike with 350w hub motor
Ryan Vanguard recumbent LWB with a 36v Cyclone 350w middrive and a 56v MAC 5t in the front hub.
Manbeer   1 kW
Post by Manbeer » Aug 08 2021 7:21pm
These look perfect for a frame pack. Where are you located?
999zip999   100 GW
Post by 999zip999 » Aug 10 2021 12:06pm
Is this a too good to be true endless-sphere battery scam.
Stu Summer   100 W
Post by Stu Summer » Aug 10 2021 7:17pm
Seems like it.
Ellectrico   100 mW
Post by Ellectrico » Aug 10 2021 8:05pm
Stu Summer wrote:
Aug 10 2021 7:17pm
Seems like it.
999zip999 wrote:
Aug 10 2021 12:06pm
Not a scam. I sell on facebook as well so I can provide links.
Everything is being sold through paypal so you get your money back if the quality is sub par.
I am located in California and ship usps ground.
Shipping costs 19.95 for 1 battery and the box can fit up to 6. I've sold many of these batteries on this forum in the past years, you can dig through my profile and see for yourself.
The Toecutter   10 kW
Post by The Toecutter » Aug 12 2021 12:06am
I bought one of these packs last year, and installed it in January of this year. It delivered about 10 AH, and I put about 3,000 miles on the pack before upgrading to a Greenway 46.8V 15.5AH pack from batteryhookup.com. This pack was still very usable, but I wanted more than the 40-60 miles range it was giving my electric velomobile. For the price tag, I was not at all disappointed. It took me about 20 minutes to install some Anderson 40A powerpole connectors and it was ready to use, even if not 100% plug and play it was close enough. It came in a black steel case.
Had the seller responded to me sooner, I'd have bought a second pack and ran the two in parallel, but by the time he responded months later, I'd already gotten two Greenway packs.
Below is a pic of it installed in my build, underneath the boom:
You can find more info about this build in my signature. But suffice to say, the pack was not a scam, and it worked.
Custom electric velomobile, 1500W: viewtopic.php?f=6&t=110298
sfebikeguy   1 µW
Post by sfebikeguy » Aug 12 2021 6:59am
I’m interested in buying 4 batteries from you. I’m in San Francisco where are you located in California?
Dean
Manbeer   1 kW
Post by Manbeer » Aug 17 2021 8:23pm
seller shipped pretty quick and i should have this in a couple of days. will report back when i have a chance to run it, probably over the weekend
Manbeer   1 kW
Post by Manbeer » Aug 22 2021 8:06am
update, the battery arrived quickly and tested damn close to rated capacity. Comes in a metal case that is actually pretty nice but uses odd connectors. It would be pretty easy to get some abs sheet or sheet metal and make a new end caps for this if you want to reuse it. Otherwise expect 15 or 20 minutes of removing silicon to safely slide the inner pack out. I accidentally tore the shrink wrap So I did a bit of dissection and these are indeed genuine cells
exe   10 W
Post by exe » Aug 23 2021 12:47pm
Manbeer,
how do you contact the seller? I PM and never got a reply.
Also, are the measurements provided with the metal case or not?
"Measurements: Lenght: 15.5 Width: 2.7” Height: 1.5”"
Thanks for info.
The Toecutter   10 kW
Post by The Toecutter » Aug 23 2021 1:24pm
exe wrote:
Aug 23 2021 12:47pm
I had this issue as well. I wanted to buy another pack to do a cheap upgrade, and after about 2 weeks passed and I heard nothing, I ended up buying a different type of battery altogether from a different seller. He didn't get in touch with me until about 2 months after the fact, which by then I was no longer interested. His loss as much as mine.
BUT this seller is definitely legit. Everything I've purchased from him has been usable and in excellent condition, and I am not disappointed. Just don't expect a prompt response.
Manbeer   1 kW
Post by Manbeer » Aug 23 2021 5:31pm
Yes, I get the feeling they probably have other businesses or jobs as well and don't check the forum too often. they did stick to their word regarding shipping and the product checked out though.
If anybody wants, PM me and I will give you their email as I'm not sure if they would want it publicly posted or not but it will probably be easier to reach them in real time via that channel
Twistgripper   100 mW
Post by Twistgripper » Aug 26 2021 4:42am
Will you ship to Canada? cost?
justlooking808   1 W
1 W
Post by justlooking808 » Sep 01 2021 7:14pm
interested in the batteries too, can someone pm his email? :D
LCLabs   1 µW
Post by LCLabs » Sep 01 2021 8:19pm
PS sent
justlooking808   1 W
1 W
Post by justlooking808 » Sep 07 2021 5:08pm
hmmm, guess not to motivative to sell. i guess this is just a teaser or very slow seller.
good luck with your sale :bigthumb:
Ellectrico   100 mW
Post by Ellectrico » Sep 10 2021 1:44pm
Hello everyone! I'm super sorry for making you all wait, it's been overwhelming the last few weeks.
I started working for a liquidation company as I mentioned above and they stretched me pretty thin. I requested a transfer to the customer support department so I can reply and sell only without any other side tasks.
Please PM me directly and I will reply to you within 10 hours at most. Thank you for your patience
Ellectrico   100 mW
Post by Ellectrico » Sep 13 2021 6:29am
41 packs still available
DogDipstick   100 kW
Post by DogDipstick » Sep 13 2021 8:41am
Is this JAG35?
84v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Ok So that was what you call a "glitch:" :twisted: (...No Mom. The formula is Kaw > 1(Hr) = Impounded. The math checks out. I'll be fine. ).. :? Broke20Horsies! 17,830w !! :x 1 (pound / second) Horse Power = 338.24 M^2 Kg^2 / Sec^4 ( :twisted: prove me wrong :twisted: ) :| (Taramps?Yall?) :confused: Fabricator @ BSECo. Inc.
Ellectrico   100 mW
Post by Ellectrico » Sep 13 2021 3:43pm
No, it is not JAG, please read my extended reply on my other threads that you are following and asked THE SAME exact question on each of them.
Once again, I am not JAG and not affiliated with him. Sorry you had a bad experience with him, but this won't make it better.
Skippo   100 mW
Post by Skippo » Sep 21 2021 7:45pm
Anyone other than Toecut actually get their battery?
justlooking808   1 W
1 W
Post by justlooking808 » Sep 21 2021 10:09pm
Skippo wrote:
Sep 21 2021 7:45pm
idk, was ready to buy, but guy went silent. so ..... maybe i should wait a bit. :shock:
