EU - 48V 20Ah Lifepo4 (unused)
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
titooon2014   10 mW
Post by titooon2014 » Oct 20 2016 4:43am
Hello ES Members,
I have a few 48V 20Ah Lifepo4 Battery pack for sale.
They have been bought from Crystalyte Europe early 2013 (1100 euro each), for a project that never went on.
They were never used, except for one charge/discharge cycle this month to ensure they are still new. They were stored at 50% discharge and seemed to have very little self discharge.
So far I have tested 2 Units, that provided me 970 Wh from full charge to BMS cut off, at a discharge rate of 9.5A (450W discharge).
All units shipped will be > 960Wh
So they are still delivering 100% of their capacity.
Will ship to European Union only.
Specifications
15s2p Lifepo4 battery pack
Factory Sealed in a blue PVC shrink wrap, CE marked.
BMS with balancing, 45A continuous discharge and 8A continuous charge
Dimensions 105 x 140 x 385 mm
Weight : around 9 kg
BMS can be easily modified to increase the specs, or change the number of cells (down to 2 cells), instructions with pictures can be provided if needed. At the moment, you have 1x 75n75 mosfet for charge and 8 x 75n75 mosfet for discharge. BMS has space for up to 10 mosfets, and replacing them for better models (IRFB3077 for example) is easy.
4A Charger Included with 220V standard plug
Price : 449 Euros including Shipping
Please contact me if you have any questions
dafex   1 mW
Re: EU - 48V 20Ah Lifepo4 (unused)
Post by dafex » Oct 22 2016 1:40pm
Hi titooon2014,
How much packs do you have? I need 4.
Regards Josef
titooon2014   10 mW
Post by titooon2014 » Oct 23 2016 3:32am
Hello Josef,
I have 4 identical packs in 48V yes. Are you in Europe ?
If you have a particular application for them and you have some technical questions, feel free to ask!
Antoine
dafex   1 mW
Post by dafex » Nov 06 2016 5:48am
Servus Antoine,
I got your PM, but i didn't get the pictures. Maybe you can put the pictures in this thread.
Ciao
titooon2014   10 mW
Post by titooon2014 » Nov 06 2016 9:11am
Hello dafex,
Here are some pictures :
48V battery pack modified for 24V - 7s4p (solar application) - still I did put the remaining 2p on the picture, FYI I normally do not intend to sell this pack since I opened and modified it.
I removed two cells to get 2 times 7s, then modify the balances wires to connect all 4p together.
I have 2 x 48V packs in stock unopened.
48V Battery pack modified into 24V (7s4p)
Here is the model of the original cells configuration of the 48V pack. If you use the png picture, you will see the + and - of the batteries, in red and black.
I unwrapped one cell to look for a serial number (bottom right corner first picture)
as well as took pictures for dimensions
18 x 65 x 130mm
Cell measure 1
Cell measure 2
Cell measure 3
I will upload later the 2 packs in 36V30Ah configuration that I have which is a bit different, and more cells (36)
dafex   1 mW
Post by dafex » Nov 07 2016 3:25pm
Thanks for the Pictures.
It seems the terminals are screw type, right? In that case, it should be easy to rebuild a new pack.
titooon2014   10 mW
Post by titooon2014 » Nov 07 2016 9:53pm
Hello dafex,
No they are not screw type, if you look closely you can see the welded busbars on the picture.
However, it is very easy to remove/solder additional busbars in order to customize the config.
If you have a specific configuration in mind, don't hesitate to send me some drawings !
