SOLD
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
PRW   10 kW
SOLD
Post by PRW » Mar 27 2017 2:06pm
I am looking at selling my Hanebrink X2 - the 48v version. I am not riding it as much as I thought I would - just too many bikes! $2,600 plus shipping cost from Sunnyvale, CA
Details are here:
https://www.electricbike.com/hanebrink/
https://www.youtube.com/watch?v=C3WRTzclB4M
http://www.electricbikeaction.com/and-n ... different/
Highlight features:
FASTACE Dual Crown Triple Clamp 740mm 8" travel
Magura MT2 Hydraulic Brakes 160mm rotors
Full Speed Ahead Crank & FSA Pig Headset
Hussefelt Truvativ bar, stem and seatpost
Bontrager seat clamp & fasteners throughout
Anderson Connectors throughout
Shimano SORA components w dual left hand shifter (custom! Leaves all electric controls on right side, very slick)
20" x 8" Tubeless ATV tires on 1lb custom USA built rims
Custom low standover (for offroad) aircraft aluminum frame
Optional 48v system upgrade
Optional Megarange 14-32T 7th speed
Optional BOXGUIDE DH Chain Guide/Tensioner
Optional Cycle Analyst fully programmed
ODI grips
Pretty much will climb ANYTHING and does a steady 25mph on throttle only. 35+ with pedal assist. Of course it's mid drive with 2 front sprockets (after the front drive! Hanebrink exclusive) so you can pretty much dial in any gear and keep the motor spinning at peak torque. It's amazingly reliable and cool running.
Website Description: http://danhanebrinkbikes.com/models/hanebrink-x2/
A 750-watt/1200-watt peak brush-less electric motor drives a fourteen (14) speed gear configuration that drives this bike. Steep grades are easily handled by the motor’s unparalleled torque.
The 51″ wheelbase and 20 inch diameter x 8 inch wide tubeless monocoque wheels and tires, widest in the industry, provide stability in tight turns and traction on dirt, sand or snow.
Shock absorption is easily handled by the dual crown triple clamp fork. Eight inches of travel provides shock absorption in uncomfortable terrain and is able to manage the most unforgiving of mountain terrains.
Our made and designed in the USA frames are manufactured from aircraft aluminum which is both lightweight and durable. Carbon fiber handlebars and seat-post connect the rider to this extreme machine.
Hydraulic disc brakes, front and rear, provide stopping power to aggressively attack corners or steep descents.
Base Price: $7,650 USD (Reflects average range)
Color: Matte Black Standard, Custom Colors Available
Weight: 85lbs (38 kg)
Battery Pack: 48 Volt LiNMC
Range*: 40 miles
Motor: 750/1200 Watt Sealed Brushless
Gearing: Motor Integrated 14 speed with low-range gearing available
Tires: Tubeless 20″ x 8″ (50cm x 20cm)
Wheels: Monocoque, Aluminum Axles, Sealed Bearings
Wheelbase: 129 cm – 51 inches
Frame: 6061- T6 Aircraft Seamless Aluminum Tubing
Fork: Dual Crown Triple Clamp 8″ Adjustable Travel
Brakes: Hydraulic Disc Brakes
Derailleur: Shimano
Heavy Duty Rear Rack: 8″ x 21″ Aluminum
Additional notes: additional options
low range gearing,
higher capacity controller
cycle analyst.
Website pics:
PRW   10 kW
Re: Hanebrink X2 for sale
Post by PRW » Aug 26 2017 4:17pm
bump!
PRW   10 kW
Post by PRW » Oct 28 2017 12:24pm
bump - price now reduced to $2,600 plus postage
Clyon2   1 mW
Post by Clyon2 » Dec 17 2017 9:43am
Do you still have it?
PRW   10 kW
Post by PRW » Dec 17 2017 6:23pm
Clyon2 wrote:
Dec 17 2017 9:43am
Yes, still available
aaronrobinson53@hotmail.com   1 µW
Post by aaronrobinson53@hotmail.com » Jan 25 2018 7:51am
Is this bike still for sale ?
Can it be shipped to Qatar ( land of sand ) ?
contact me aaronrobinson53@hotmail.com
PRW   10 kW
Post by PRW » Jan 25 2018 10:59am
aaronrobinson53@hotmail.com wrote:
Jan 25 2018 7:51am
I have sent an email.
