LG Chem 10S2P battery modules - 37V30Ah - 1100 wh [EU] [SOLD]
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
Monstarr   100 W
Re: LG Chem 10S2P battery modules - 37V30Ah - 1100 wh [EU]
Post by Monstarr » Aug 09 2018 9:33am
Monstarr wrote:
Aug 03 2018 1:24pm
I have two sets of 2 modules available. The project which i have used these in for a couple of months is now dismantled because I wasnt very pleased with the weight distribution of the modules in the scooter frame. I did not put them in the original position so it lead to bad road handling unfortunately.
I used 2 modules in series with another similar pack in parallel.
Plan is to rebuild the original 18650 (440 cell) battery for an increased energy density pack which i can mount better and lower. I dont need the power which these modules can produce & I dont have any use for these modules for the foreseeable future so they take up valuable space in my shed.
So I will sell these per two, 275 eur per pack. The 20s modules come assembled with the balancing wires included. +-1 meter leadcables with protection mantle.
Cells did not see a lot of cycles - possibly around 30-40 shallow cycles - 90 -> 50% in my useage. Saw something around 15-20 k km in the Volvo V60 they came out off.
One 2.2kWh set (2 modules) left. :idea:
TilmanBaumann   100 W
Re: LG Chem 10S2P battery modules - 37V30Ah - 1100 wh [EU] [SOLD]
Post by TilmanBaumann » Aug 22 2018 11:49am
Thank you Monstarr
Have to still fabricate some bus-bars and parallel the cells...
btw, what do you think? I guess paralleling those cells balance wires should be enough I guess?
Or should I go with something thicker gauge?
I don't just need to parallel the packs. O also need to parallel the cells within. If you wonder what I mean.
I have four pack a 10s2p. I need to reconfigure them to achieve 20s4p.
Monstarr   100 W
Post by Monstarr » Aug 29 2018 12:44pm
TilmanBaumann wrote:
Aug 22 2018 11:49am
Thank you Monstarr
Hi man,
Sorry for late reply. Been somewhat of a pretty hectic period the last weeks for me.
But yeah looking good! They seem like a great fit for your frame.
What I know about paralleling packs is that each series combination (so 20s2p in this case) should need their own BMS device which can shut it off. Thats the way it is also done in large storage batteries etc. Making designing the protection electronics side a bit tricky with off the shelf 'dumb' BMS systems.
I don't really have a lot of experience with the way you are paralleling them. So cant give any advice about it. But if you manage to physical parallel them while still being mounted in the double 20s2P config then kudos for you! :mrgreen:
TilmanBaumann   100 W
Post by TilmanBaumann » Aug 29 2018 1:18pm
Thanks, no worries I think it will all be good.
I don't think the balancing loads will ever be higher than the balance cables can handle during discharge. Except for total cell loss perhaps.
I will just Y-wire the balance cables.
Two strings with two BMS is madness and only good and safe under certain conditions.
https://www.orionbms.com/general/using- ... l-strings/
I will of course parallel the individual cells. :wink:
Monstarr   100 W
Post by Monstarr » Aug 29 2018 1:22pm
Aug 29 2018 1:18pm
Great. While I look a bit closer at your picture. Make sure the modules are not able to touch at the terminals. How I look at it you have a bit of a short circuit risk there.
Monstarr   100 W
Post by Monstarr » Nov 11 2018 6:48am
Got new modules!
Anybody interested?
1 pc: 175€
>1pc: 150€/pc
Solexelec   1 W
1 W
Re: LG Chem 10S2P battery modules - 37V30Ah - 1100 wh [EU] UPDATE NOV 18
Post by Solexelec » Nov 11 2018 2:37pm
Hello
Can you think it's possible to disassembled for build
14s battery?
eee291   100 kW
Post by eee291 » Nov 11 2018 3:00pm
Yes, I have made custom packs, but be warned it is not easy.
This is the only pic I have of an unfinished Pack.
ben--b   1 mW
Post by ben--b » Nov 12 2018 1:58am
PM sent
Monstarr   100 W
Post by Monstarr » Nov 12 2018 2:41am
Solexelec wrote:
Nov 11 2018 2:37pm
Hello
14s battery?
Yes, as mentioned above, it is possible but not in a 'bolt-off bolt-on' way. The relative easy way is that you dissect two modules in 7s and 3s and make a new connection between two 7S sections. Leaving two 3s modules spare.
The other option, which i do not recommend, is to seperate all cells. Leaving you with 20 cells per module. With 1 module you can build a 14s1p (15Ah) pack.
SlowCo   1 MW
Post by SlowCo » Nov 12 2018 2:52am
Are the black plastic dividers bonded together and difficult to separate? Or are only the tabs welded together to make the electrical connections?
Monstarr   100 W
Post by Monstarr » Nov 12 2018 3:00am
SlowCo wrote:
Nov 12 2018 2:52am
There is some overlaying plastic protection you need to get rid off but generally speaking the dividers are seperate. The cells on their own are physically only connected via the tabs. On both sides of the module there are steel clampplates which are connected and therefor clamped by 4 threaded rods. If you remove anything which would make the module slimmer, like the cooling plates, you have to get new M5 threaded rods because the original rods only have threads on a few cm which is not enough for the clamping.
PITMIX   100 W
Post by PITMIX » Nov 19 2018 4:06pm
Hello,
I ordered you 4 modules 10s2p-37V30Ah last night. Currently I use two packs Li-po 16s10c16Ah.
To have the same configuration to get the same voltage on my vehicle.
I need to turn the 10s modules into 8s.
This seems possible to do or is it too complicated ?
Thank you in advance
Peter
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
SlowCo   1 MW
Post by SlowCo » Nov 19 2018 4:23pm
PITMIX wrote:
Nov 19 2018 4:06pm
Hello,
Peter
Or just keep them 10s and get a programmable controller that can handle 20s. What is your vehicle, motor and controller set up?
Monstarr   100 W
Post by Monstarr » Nov 20 2018 2:23am
PITMIX wrote:
Nov 19 2018 4:06pm
Hello,
Peter
Hi Peter,
I mentioned this before, i do not recommend it when you don't know exactly what you are doing with eye on safety and build quality.
Best to leave them in 10s.
Always be sure to use appropriate battery protection with quality BMS. monitoring & encasing.
Also don't charge below 10 degrees Celcius.
PITMIX   100 W
Post by PITMIX » Nov 20 2018 5:40pm
Ok, thanks for the response. I suspect you can not recommend doing dangerous things on a forum.
My motor is a car alternator modified brushless 5kW motor and my controllers are Chinese at 30 €.
It takes 2 controllers to operate this double coil motor.
Currently everything works very well but it is necessary to increase the autonomy.
My vehicle is a small car diesel without license modified in electric.
I saw the controllers who look very good :
https://endless-sphere.com/forums/viewt ... 31&t=75494
Monstarr   100 W
Post by Monstarr » Nov 21 2018 10:32am
PITMIX wrote:
Nov 20 2018 5:40pm
Indeed, li-ion cells need to be handled and used with great care and only be used with adequate protection for itself and the environment and with monitoring at all time.
Please check your PM inbox.
PITMIX   100 W
Post by PITMIX » Nov 21 2018 2:59pm
Hello I replied to your private message.
Don't worry, I know what the dangers are. I use lipo 16Ah for example to roll various prototypes DIY.
I use lipo alarms as well as bms of different power. For these batteries I will order 4 news bms 20s because I can power my vehicle in 2 x 16 s or 2 x 20 s with 2 controllers on a motor with double windings type pseudo part-winding.
So I absolutely need 2x16s minimum and 2x20s to be at the top of my engine performance.
Here is for example 1 of my packs lipos 16s 16Ah with a BMS and cards JST XH completely removable
I use this box for my lipo pack
Also see a video where I explain how to modify a LIPO 4S battery with a LIPO 3S dead cell.
This manipulation can only be done if one is aware of the risks of working under tension. It must be done with great care and not done without the appropriate knowledge
lipo 16s 16AH BMS.png (257.35 KiB) Viewed 2279 times
Monstarr   100 W
Post by Monstarr » Nov 22 2018 8:07am
All good :mrgreen:
PITMIX   100 W
Post by PITMIX » Dec 04 2018 9:22pm
Hello I give you news of my batteries. I made the connection of the 14-pin plugs for the balancing wires of the elements. In a few days I will receive you my BMS 20s.
Repérage des bornes équilibrage
Raccordement des fils d'équilibrage sur les fiches 14 broches
Schéma complet Pack 20s 2p 30Ah + BMS 20s
PITMIX   100 W
Post by PITMIX » Dec 04 2018 9:46pm
I am also waiting for a power supply 230VAC / 48VDC + a booster 0 to 120VDC 900w adjustable.
This will serve me to make a DIY charger.
With this charger I will be able to charge my lipos Multistars 16 and 12 elements, and also the Packs LG 20 elements up to 84v without problem.
Schéma complet chargeur 230VAC/0 à 120VDC 900W
PITMIX   100 W
Post by PITMIX » Dec 07 2018 12:17pm
Hello,
I finished editing the 2 packs in 20s 2p30Ah.
I prepared a dump bench to test the actual capacity of the batteries. I use a heating resistor of an old air conditioner and the resistance of my electric barbecue.
Under 72V it is a charge of 5A is about 360w.
The 30Ah should empty in about 6 hours.
2x Packs 20s 30Ah + BMS + Résistance 72V 360W
Pack 20s avec banc de décharge.png (508 KiB) Viewed 2063 times
Xtr6   100 W
Post by Xtr6 » Dec 14 2018 1:51pm
Do you still have these for sale?
Monstarr   100 W
Post by Monstarr » Dec 14 2018 2:04pm
Xtr6 wrote:
Dec 14 2018 1:51pm
None left, sorry.
Boekel   1 mW
Post by Boekel » Dec 19 2018 6:43pm
I have a couple left (Netherlands, Europe)
