Tidalforce S-750 custom frame battery cases
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
ashlandelectricbikes   100 µW
100 µW
Post by ashlandelectricbikes » Jan 30 2018 4:06pm
I'm finally ready to part with my last 3 triangle cases that I made some years back. The frame is machine bent and powder coated aluminum. The covers are textured ABS with a layer of expanded PVC sheeting glued inside that serves for positioning/alignment. The interior width between covers is 2.75". Included is an XLR charge port.
The frames are drilled to mount to the bottle cage bosses along the bottom leg as well as two points along the upper case that requires drilling into the underside of the top tube of your frame with an angle drill (due to the tight spacing). What IS NOT INCLUDED are the 3 dowels required to affix the covers to each other. I always wanted to have some aluminum dowels drilled and tapped but never got past using hardwood dowels and stainless screws, which work just fine. Sometimes you just gotta git 'er done!
The largest capacity I achieved was 48Vx10AH using 13 Tenergy #30123 LiPo cells. I haven't been keeping up with battery options, so I can't say whether that can be topped yet with another type of cells.
The photos show 1 of the cases that was used as a guide for trimming all the covers, and its been scraped a bit accordingly and will require painting. The other 2 frames are in immaculate condition as are all the covers. Pricing including shipping is as follows:
1 scraped frame - $110
2 perfect frames - $130 each
scraped case detail.JPG (137.14 KiB) Viewed 659 times
dual crown wind runner battery case 1.jpg (224.57 KiB) Viewed 659 times
case, covers, XLR port.JPG (202.86 KiB) Viewed 659 times
dual crown wind runner battery case 2.jpg (219.57 KiB) Viewed 659 times
Last edited by ashlandelectricbikes on Feb 01 2018 2:13pm, edited 1 time in total.
ambroseliao   100 kW
Re: Tidalforce S-750 custom frame battery cases
Post by ambroseliao » Jan 30 2018 4:31pm
Beautiful work!
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
Rube   100 W
Post by Rube » Jan 31 2018 4:45am
Hi, would you mind sharing how you developed the textured ABS? Did you use moulds or was it a handmade process? Perhaps I missed this in another thread.
100 µW
Post by ashlandelectricbikes » Jan 31 2018 3:41pm
I can't take credit for that. Its just a standard style of ABS sheeting that's available. Its great because it hides many of the little nicks that undoubtedly occur over time.
amberwolf   100 GW
Post by amberwolf » Feb 02 2018 2:59am
They also make Kydex like that; its' tougher in some ways than ABS if you need that.
kauaikit   100 mW
Post by kauaikit » Feb 04 2018 1:01pm
PM sent.
Kit
Kit- Wavecrest Lab Tidalforce ebikes (11-all models), EMS M-750 E+, EVG ebikes (18-all models), Ultra Motor Velociti (26" White), Tres Terra Europa 36v (2-Blk & White), iZip Trailz step 24v, Chinese 29" 36v alum man-bike, Chinese ped-scooter 48v, iZip 1000 36v scooter, Tanaka 36v scooter.
