DAHON MATRIX 26" folding ELECTRIC mountain bike with BMC 600watt V2 motor, Cycle Analyst 2.1, extras.$850 Firm
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
nightowlgk   1 W
1 W
Post by nightowlgk » Feb 11 2018 3:52pm
DAHON MATRIX 26" folding ELECTRIC mountain bike with BMC 600watt V2 motor, Cycle Analyst 2.1, extras. In Thousand Oaks, CA
If the ad is up, it is still available. Email me your name and phone number and a day and time you want to see it, and I'l get back to you asap. Will update or delete below items if sold.
DAHON MATRIX 2009 med. size 26" folding MTB w/ Thudbuster seat post, front suspension fork, Origin 8 Spacebars for comfortable ride. Rear rack with Topeak MTX bag w/panniers. Heavy duty MTB tires. Quick release front wheel. Folding pedals. Cannondale heavy duty kickstand. Folds easily with included hex wrench tool, I hardly ever folded it.
Converted to ebike. you can easily remove the battery box and still pedal with the 9 lb. motor freewheeling. Disc brakes work but could use new pads.
Will consider selling bike only (without rear wheel)
BMC V2 speed 600 watt motor purchased from Ilia Brouk (ebikessf.com) w/ 7 sp. freewheel. 2 torque arms on rear motor axle.
Great geared rear hub motor- fast and torquey. link on BMC motor: https://endless-sphere.com/forums/viewt ... =4&t=22103
Battery and controller are mounted in center triangle for optimum, low center of gravity. Much better than a rear rack battery mount like Prodeco.
CRYSTALLYTE 36-72v 35 amp analog controller, CLYTE Twist Throttle
Cycle Analyst 2.1 battery aHr meter/speed computer w/ limit switch to conserve battery.
Ping 15ah 36v Battery with BMS set to 40amps continuous- mounted in custom box in triangle. Comes with charger.
The battery had a good, long life but now goes only about 4-6 miles, depending on how much you pedal. Will need a new battery to go far. I can recommend this : http://www.ebikes.ca/b3614lim-dt.html# an excellent, matched battery for $485 shipped.
Original cost:
Bike: $750
BMC Motor and controller, throttle, Cycle Analyst 2.1 package: $900
Thudbuster seat post: $120
Spacebars $40
Rack and Topeak bag $125
Cannondale heavy duty kickstand. $40
Ping 15 aHr Battery $450
Total: $2425
Sell all for $850 FIRM. Buy the brand new battery for $485 and you have a 26 mph, 30-40 mile range, suspension hill climber for under $1350.
Factory specs for bike: Wheel Size : 26"
Weight : 12.9 kg (28.4 lbs)
Folded Size : 35 × 97 × 85 cm (13.7" × 37.8" × 33.2")
Frame : OAX Series, 7005 aluminum, patented LockJaw hinges, replaceable derailleur hanger, integrated head tube
Fork : Suntour NEX, hydraulic damping, lockout
Handlepost :Kinetix Comp, riser, double butted 6061, 31.8 mm
Drivetrain : Front Derailleur Microshift, forged aluminium, for MTB Rear Derailleur SRAM X7, long cage, black Crankset FSA Dynadrive,
Wheels : Front Hub Formula disk, 32H, double sealed Rear Hub Formula disk, 32H, double sealed Spokes 18/8 stainless steel or Sapim Leader, stainless steel (EU) Rims WTB SX24, disc only,
Brakes : Avid BB5, disc
Rider height : M: 167 - 183 cm (5'6" - 6') L: 183 - 193 cm (6' - 6'4")
Max Rider Weight : 105 kg (231 lbs)
DAHON MATRIX 2009 26" folding MTB w/ Thudbuster, Origin 8 spacebars.
BMC V2 speed model from Ilia Brouk w/ 7 sp. freewheel
CLYTE 36-72v 35 amp analog controller CLYTE Twist Throttle
Cycle Analyst 2.1
Ping 15ah 36v BMS set to 40amps continuous- mounted in triangle.
Also: Torpedo Battery. 3- Bosch Fatpacks in plastic tube.
Previous bikes:
Wavecrest Tidal Force M-750X, S-750X
Currie I-Zip Cruiser Enlightened Nimh - smooth and light but underpowered
WE-600w brushless SLA
nightowlgk   1 W
1 W
Re: DAHON MATRIX 26" folding ELECTRIC mountain bike with BMC 600watt V2 motor, Cycle Analyst 2.1, extras.$850 Firm
Post by nightowlgk » Feb 15 2018 5:59pm
Bump. Ping also has a new 36v/ 15aHr battery with high rate BMS to replace this. $445.
http://www.pingbattery.com/36v-15ah-lit ... tery-pack/
Or: Luna Cycle https://lunacycle.com/36v-panasonic-sha ... 17-5ah-ga/
Cycle Analyst 2.1
Previous bikes:
