Tesla Cells for sale as wrapped or welded packs
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
eric1565   10 W
Post by eric1565 » Apr 17 2018 7:52pm
Hello,
I am selling Tesla cells either wrapped or in welded packs. I have a JP spot welder, and I have made MANY packs for people. I know how to remove the cells with out damaging them. I do not use any hammers or anything removing the cells. They will be 100% perfect when you get them. All cells will have paper washers on the positive terminal and will be shrink wrapped
I can make packs any shape you want. I use custom made hex style holders. These holders give about a 5%-8% increase in density vs the square Chinese holders. I can do any size and shape. I am not going to put on the main lead wires, or balance leads. I will lay down a good amount of nickel to protect the cells from the heat of soldering. If you want that done it will cost more per cell and it will be on an individual case.
i have made packs for my self, and you can see some of that on my youtube channel under eric.ensley I currently have a 2X 7S7P approx 59V with a speed controller set to 150 amps. That is about 20 amps per cell.
I do not sell/ship unwrapped cells due to cells shorting, it is dangerous, so please don't ask.
Prices are below.
If you are interested in cells please PM me. I accept paypay or cash if you are in the houston Tx area.
eric1565   10 W
Re: Tesla Cells for sale as wrapped or welded packs
Post by eric1565 » Apr 18 2018 10:03pm
I forgot to put in some of the packs I have made in the past for people.
This one was for an E-bike. It was a BIG pack... 80V+ 10P I think
In process. I really like the wide nickle strips. It really speads up the assembly/weld time.
Custom ebike frame. The customer and us cadded it all up and the model said it would work... I was a bit scared the first time I put it together because I was afraid it would not fit, but it fit like a glove! This was set up in 2 separate packs for the guy, each 40V+ 14P
Example of a Gen 1 pack. I don't make these anymore.
Another example of a Gen 1 pack using Chinese holders. Chinese holders suck because you can only use 8mm nickle and you have to lay a TON of nickle to get the amps up. I always mark on the packs to mark where the cell groups are. It helps when you are building and laying down the nickle.
This is an example of us working with the customer to find out how they wanted the wires run, and where he wanted the Pos and Neg to be. We can do anything, just take communication
Thank you
Eric1565
litespeed   100 kW
Post by litespeed » Apr 20 2018 8:18pm
So what kind of sag do you get a 20 amps. I thought those maxed at 10 amps? What cell is this exactly since I’ve never been able to figure that out? Panasonic what?
Tom
eric1565   10 W
Post by eric1565 » Apr 21 2018 10:11am
There are a ton of power graphs on Tesla motors club. But from memory they go from about 4.1v to about 3v at about 20 amps per cell.
We believe the cells are 18650BE or a chemistry very close to that. Okashira has done significant testing on tesla cells. You can search his posts from 2015 time to see what he thinks. He believes the 3.1ah is better at dumping power vs the 3.4ah cells.
Eric
eric1565   10 W
Post by eric1565 » Apr 22 2018 7:57pm
Here is a P85DL doing a 0-100
MikeBur P85DL Dry Run 55F Ludicrous Mode Launch 0-100.PNG (106.09 KiB) Viewed 3364 times
Looks pretty close to what I said above. about a 1V drop at 20 amp pull.
Eric
Endlesscube23   1 µW
Post by Endlesscube23 » Apr 28 2018 1:06am
Hey. Can you build a 52v 30ah triangle battery that would fit the frame of a motobecane hardtail mtb?
eric1565   10 W
Post by eric1565 » Apr 28 2018 8:36am
I can build anything you want. If u have cad u can cad up what u want. Cells are a hex layout. I need to get u all the ctr to ctr distance but from memory the hex wall is .05" so u can add .05" to the 18mm dia So about .76" dia then just pile them in how u want. If u don't have cad then a picture with dims is enough for me to design up a pack.
Thank you
Eric
StinkyGoalieGuy   100 W
Post by StinkyGoalieGuy » Apr 30 2018 12:30pm
Can you give an accurate outside diameter using calipers of the wrapped cells? I want to make sure they will fit my holders.
eric1565   10 W
Post by eric1565 » Apr 30 2018 9:49pm
With wrapper 18.35-18.37mm
Without wrapper 18.20-18.22mm
Measured with precision Chinese calipers (tongue in cheek)
Eric
eric1565   10 W
Post by eric1565 » Apr 30 2018 9:51pm
Eric
eric1565   10 W
Post by eric1565 » Apr 30 2018 9:52pm
Also on the hex holders the cast urathane ones are 1.2mm thick walls and the 3d printed ones are .8mm thick.
RootedSuperuser   1 W
1 W
Post by RootedSuperuser » May 07 2018 11:11am
I will buy a module (Or 2), from which cells do you have them from?
heynow9991   10 mW
Post by heynow9991 » May 15 2018 8:22pm
deleted
spinningmagnets   100 GW
Post by spinningmagnets » May 15 2018 8:43pm
I think the hex shape of end-cap has the opportunity for better air-flow. More compact of you don't need air-flow, and better air-flow if you spread them out.
kriskros   10 kW
Post by kriskros » May 16 2018 2:24am
can you build a 54.4 [48.1v nominal]30ah pack with a 40amp BMS?? what would dimensions be?? I domt know the specs of Tesla cells .and what is cost uincludind shipping to Canada L1H3B7. thanks
eric1565   10 W
Post by eric1565 » May 16 2018 7:40pm
I am not going to ship to Canada. US only. Sorry, shipping to Canada is a PITA.
also I don't have any good BMS boards. There are a few people have used on ES, but I have no experience with them. I don't want u to be a guinea pig.
Eric
molybdenum   100 W
Post by molybdenum » May 17 2018 1:17pm
Would you consider shipping to a US border address such as MyUS.com. Those of us canucks lucky enough to live near the border could register with myus.com and drive across to collect the package (and declare at border).
2012 Kona Dew Deluxe, Q128C and 9spd cassette, S12S sinewave controller, 48V Panasonic battery
eric1565   10 W
Post by eric1565 » May 17 2018 4:26pm
As long as it is in the US I'll ship. If u want to make urself a mule and start haulling packs accross the border go for it :).
Eric
heynow9991   10 mW
Post by heynow9991 » May 24 2018 3:12pm
Hi Eric
I have a stealth fighter that I need a battery pack for. The opening is 120mm x 380 mm. I would like to have a 14s9p battery.
I came up with this drawing. Do you have enough cells to build it?(126) Can you do it? could you tell me how big it would be before you build it? I am most interested in the width (across the 6 1/2 cells) as that is where it would be tight.
I made a small mistake tracing out the cells on the right side of the drawing. Disregard that, im sure you know what I want.
thanks
Peter
eric1565   10 W
Post by eric1565 » May 24 2018 5:07pm
Yes that is not a problem. I do like how you have 3 cells touching where the cells jump from + to -, or vise versa. This will give you a good amt of nickel to push the amps thru.
So what amp range are you looking for? I need to know this so that I make sure there is enough nickel to take the amps.
Eric
heynow9991   10 mW
Post by heynow9991 » May 24 2018 7:22pm
about amp draw, I really dont know. Im not a kid so im not looking for crazy performance, but it would be nice to be able to use the bike to its full potential. If you did the nickel strips like this, that would give 3 strips going between each group of cells. What do you think of that? How about using wider nickel bands that I see in some of the other packs you have built? If the bike has a 3000 watt motor and the battery is ~50v, 3000/50=60 amps So how about 60 amps?
Just so we are on the same page, I drew how I would like the current to flow through the battery. As you can see, the current flows across the top from left to right, then drops down to the bottom an goes right to left. This way the positive and the negative end up beside each other so there is no need for a wire to run the length of the battery
Let me know what you think. How long to build, do you have 126 cells, and what mah are they?
Thanks
eric1565   10 W
Post by eric1565 » Jun 03 2018 2:08pm
Here is a pack I'm making for heynow. It is for a stealth fighter. He wanted a simple design.
I am currently going thru and checking all the P's to make sure their capacity's are good.
I welded on extra little bis of nickel so I could hook up my alligator clips to each cell individually.
eric1565   10 W
Post by eric1565 » Jul 02 2018 8:47pm
I am in the process of making a pack for a guy. I am 3D printing the cell holders. The filiment is nylon 6/6. I'm printing on a home built core XY printer.
Here are some pics of the prints. I need to work on the retractions because the nylon is a bit stringy. But it is STRONG.
These cell holders are a BIT tighter than the molded urathane. The Nylon has much better heat performance. The urathane has the heat characteristices of PLA, get it a bit hot and it just sags.
So if the pack is bigger than about 10x10, I cut it up into smaller sections and then just over lap a cell.
So here is an example of a triangle pack I am working on, and I had to cut it up into 3 different prints (6 actually since i need them on both sides of the cell). Each print takes about 4 hrs to finish.
parabellum   10 MW
Post by parabellum » Jul 04 2018 8:30am
Nice holders.
What is the thin, transparent base, underneath your print?
X2flier   10 W
Post by X2flier » Jul 04 2018 11:16am
kriskros wrote:
May 16 2018 2:24am
can you build a 54.4 [48.1v nominal]30ah pack? what would dimensions be?? I domt know the specs of Tesla cells
Eric,
Same question, with USA shipping. I would need to get a 48 Vdc (with 30~40 Ah) battery pack. Your printed cell holders look fine to me, but I would have to know the number of cells that I would need for my pack(s). I could CAD something up if you want, if I had the dimensions of your cell holders, maybe across five cells.
Hopefully I can figure out a decent BMS and charger set-up. I have some electronics experience, but not much experience with batteries.
Total noob to ebikes here, so please bear with me.
Thanks,
Cheers,
X2flier
