QS205 V3 hub motor stator $45
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
BCTECH   100 W
Post by BCTECH » May 04 2018 4:07pm
motor was used for around 10 rides. Then I realized the phase wire sleeve was rubbing and eating up almost to the phase wire itself (I have the old wire set can ship together), so I ordered a new set of wire for replacement. At the same time I bought another motor to use for the down time. I never got time to finish the replacement after and my new motor never have any problem, figured why bother.
this can be use as parts spare/replacement or someone have the time to finish the cable connections. every part works fine.
only have one side of the cover (freewheel threaded side)
Everything you see on the pic is what you get.
selling for $45
Pls PM zip code for shipping cost
Here is the Spec
QS 3000W 205 (50H) E-bike hub motor
extra/V3 type (Black)
1. BLDC Permanent Magnet Outer Rotor Spoke Hub Motor
2. Power: 50mm magnet height, 16 pole paris, 3000W rated, 3932W Peak. 36 spoke holes*4.2 & 3.4mm (Dual Holes)
3. Speed: TBD, winding 7 turns, speed 50-70KPH Torque: Depends on the speed
4. Designed to match with E-bike Disc brakes PCD6*44mm (not include Brake Disc), dropouts/Rear Bridge Clamping Width (150mm)
5. Two Halls(One for spare, in case of damage) ,10mm² Phase wire
6. Thermic Probe: KTY 83/122
7. Support regenerative braking & Reverse function
8. Waterproof grade: IP54
9. Efficiency: ≥87%
10. Stronger configuration--high grade magnet, more cooper, bear more Ampere.
11. 10mm spade half of axle
BCTECH   100 W
Re: QS205 V3 hub motor stator $60
Post by BCTECH » May 28 2018 1:01pm
lowered to $60
BCTECH   100 W
Re: QS205 V3 hub motor stator $45
Post by BCTECH » Jun 06 2018 1:35pm
lowered to $45
spinningmagnets   100 GW
Post by spinningmagnets » Jun 06 2018 4:11pm
I see QS motors with fried stators on a regular basis, so...this is a very good deal. What city and country are you in?
BCTECH   100 W
Post by BCTECH » Jun 06 2018 4:53pm
spinningmagnets wrote:
Jun 06 2018 4:11pm
I have another same motor on my current hub drive bike running for 2 years without any problem, this back up / parts has no use for me and taking up space, so I let it go for cheap. Also I am building mid drive now.
shipping out from Blaine WA, 98230
can be local pick up at Vancouver Canada
PRW   10 kW
Post by PRW » Jun 06 2018 4:54pm
from his profile, Washington, Northern California
spektrolyte   10 W
Post by spektrolyte » Jun 28 2018 5:04pm
I really want this but am in Europe.
If you can be bothered to ship I'll pay.
