I know a guy who has a pedicab with a 36 volt, 750 Bafang mid-drive. He blew the crank freewheel, after several months. So it needs this:
https://www.greenbikekit.com/accessorie ... ement.html
He is replacing it with a 1500 watt planetary geared Cyclone kit. He is looking for a buyer for his Bafang setup.
It comes with a charger, and two small shark pack batteries. No label on the batteries, so not sure of the Wh, but can't be over 350 Wh each.
Anybody interested?
36 volt, 750 watt Bafang BBS02
My mid-drive recumbent
https://endless-sphere.com/forums/viewt ... 28&t=23259
My DD cargo recumbent
https://endless-sphere.com/forums/viewt ... =3&t=78828
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Re: 36 volt, 750 watt Bafang BBS02
What kind of price? I have a coworker that's kind of considering adding some sort of power assist to his bike, but hasn't decided what (or if) he's going to do.
If it's cheap enough I could even use it to build an experimental middrive setup for the SB Cruiser trike, or Crazybike2. (would take some reworking of the pedal drivetrain first).
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
I was hoping somebody would make an offer. Through Luna or EM3ev the mid-drive and two small packs go for over a grand, plus shipping. I don't have a clue what this guy considers reasonable. I won't be offended one way or another.
I wouldn't offer much since it could be on it's last leg (or should I say gear tooth?) due to how it's obviously been under abuse.
Mush! Mush you electrons! Push harder!
- amberwolf 100 GW
- Contact:
Well, I don't have much to offer...especially for an experiment. I don't really need batteries (and used ones are worthless without known-method testing results, and info on how they've been used), so about the best I'd offer myself is $100 including shipping for the BBS02 (without batteries, unless he just wants them out of the way). Would guess that's not enough to interest him.
And I would guess that a couple hundred is the most the guy at work could afford. Where I work they dont' pay much or give enough hours. :/ (otherwise he'd have a car)
Do you still have the motor for sale ?
Is this still for sale? Please PM me if so, I am interested.
Thank you!
Thank you!
