SloNEZ
Put these on my ebike last spring and rode them for 2700 miles or so.
Both in size 26 X 2.0
The Big Apple performed very well on the front. It still had plenty of tread left, but it was "feathered" toward the back.
I'm not sure it shows, but the center tread blocks are worn more toward the rear of each block.
This did not seem to impact performance and I didn't get any flats.
I did use a tire liner, thick tube, and sealant. No sign of any sealed leaks in the tube.
Recommended. It appears only half-worn and still looks good enough to be used, but I up-sized to 26 X 2.35 for this season.
Donated it to the bike co-op.
Sorry that's sideways - danged if I can figure out how to fix it.
The H5 wore completely out on the rear powered rim.
All semblance of tread was gone by 1500 miles, and the center of the tire wore flat and thin by the end of the season.
Speaking of flat, I didn't get one. I did use tire liners and thick tubes, however.
A couple pieces of what I assume to be wire from car tires did poke through the H5 and the tire liner (!), but did not get through the thick tube.
I had sealant in there, and I didn't see any sign of a leak that had self-plugged at all.
I ride through an industrial area on my commute and hit a lot of debris that I can hear flying away from the tires at times. Rough duty.
You can call me totally impressed. So much so that I bought another for this season's riding.
I do plan on a mid-season replacement this time at about 1500-1700 miles. I think I pushed my luck last year.
I replaced the tubes for this season as Chalo has mentioned that he's seen tire liners wear on the tubes.
I didn't notice any wear, but better safe than sorry. I donated the tubes to the bike co-op.
-Slo
-Slo
