My Solar setup is done at last!
The setup is as previously posted in multiple places in this thread, but to summarise it's:
18W - 20.5% efficient 12V panel
CC-CV - 5A capable DCDC converter
2x Schottky Diodes
Cheap '150A' Watt meter
Plus a bunch of JST 2.5mm connectors and 20AWG silicone wire.
I did a little testing today and it seems really solidly mounted. Doesn't move at all. Today was a really windy day and if ever the panel would cause problems with cross-winds etc, it would have shown up today. The position above is the second attempt. The first time, it was too low and the tops of my feet would catch the panel as I pedalled. That was fixed by moving it up as high as possible. The very top of the panel is a little obscured and I had to trim off the very top corners of the panel (but not the solar cells themselves) so my hands would still fit, but I don't mind if it makes it practical and usable.
The watt meter is only temporary. I will monitor how it goes and best sun tracking positions where I park it at work, then remove it as it doesn't look great, chews up a small amount of power and just isn't necessary normally.
The only other change I'm considering is trimming off the white edges. They don't seem necessary and I think the panel would look cool without the white bezel.
I also rearranged my rear reflector. It was previously mounted to the tail of the frame, but my backpack would sag over the end and cover the reflector making it useless. I found my rear mudguard was a bit too short and would still let some rain/muck flick up into the end of the frame. Adding the reflector to the end of the guard seems to have fixed that also.
It bounces up and down when I hit bumps...adding a bit of reflector dazzle so I'm seen even better by cars.
Cheers
