LightningRods
Rotems said:I don't think that this is the right place to ask for it but you are not responding to my emails.
This is absolutely not the right place. I did respond to this person's e-mail.
RANGE shouldn't change if you re-arrange your batteries but keep total number of cells the same. the capacity you have stays the same, so does your range. so if you just ride slower with your 18s setup your range will be the same as 12s, with the advantage of sending lower amps to the motor.FluxShifter said:... 18s2p 16ah multistars for speed. 12s3p for range/pedal cadance. ...
LightningRods said:The current kit can be used on a recumbent by mounting it on the crank boom. I'm really interested in building a recumbent with the motor in between the seat and rear wheel. I have a new two jackshaft design that has a lot of advantages. On a bike with a very long chain run, like a cargo bike or recumbent, one advantage is that it separates one long and problematic chain into two more normal length runs.
I'm currently building a mid bike drive for the Lunacycle fat bike. Following that will be a Surley Big Dummy cargo bike that's on my build bench. I'd love to follow that up with a recumbent.
Deanwvu said:The Tour Easy LWB recumbent would be a good choice. Plenty of options like fairing, and plenty of space to mount a drive and batteries, etc.
LightningRods said:Deanwvu said:The Tour Easy LWB recumbent would be a good choice. Plenty of options like fairing, and plenty of space to mount a drive and batteries, etc.
I'm sure that the Tour Easy works well but -damn- that girl would need to have one great personality before I'd date her!
Deanwvu said:My Bachetta is literally just a stick with wheels and a crank--no way to reliably mount one of your rigs to it.
LightningRods said:Deanwvu said:My Bachetta is literally just a stick with wheels and a crank--no way to reliably mount one of your rigs to it.
If your bike looks like this:
I could definitely mount a mid bike drive reliably to that big frame tube. I'd have most of the drive under the frame. Certainly the drive sprocket. I think it'd be awesome. Maybe once you have your Big Dummy back home.
