stevebills
- Joined
- Jan 6, 2011
- Messages
- 249
Rix said:stevebills said:I went out on the Bomber today and the left hand side peddle complete with arm fell off and what do I need to put it on with there is a large looking alley key slot on the arm and do i tigten it clockwise?
help thx steve
On your crank arms mounting faces, you got an allen threaded cap sized 10mm and inside of the cap is the actual bolt sized 8mm. Don' touch the 10mm cap bolt. Grab yourself and 8mm allen wrench, and some grease and put that on BB outside spindle . Maybe put just a little bit of blue lock tight inside of the bb bracket spindle threads. Then torque it down. I can't remember but it seems like you don't want to exceed 35nm of torque. I have the manual on my other computer and can look up the torque specs tomorrow.
I grabbed an 8mm key from a bike shop today and sorted it so thanks Rix
