Since the standard 9C style of hub construction should work well for heat-bridging the magnet-rim to side-plate...I believe this FF upgrade will prove to be very popular for the Leafbike-1500W and the MXUS-3000W...
That's probably the best idea. I could use the one you sent, out of your early batches of the older ASI type, as it isn't on a bike yet (keep meaning to set it up on the trike for tests, but have been using the trike for transportation to/from work the last several months, and didn't wanna take it out of service if I break something doing it).justin_le said:You don't need to do any of that, just do what I've been doing on all of these runs. Use a field oriented motor controller that lets you inject field weakening current into the windings, and then you'll be able to heat up the insides exactly as if you were loading down the motor but without any of the mechanical complexity of putting an actual load on the hub. It truly works great and makes at-home thermal test experiments really feasible for anyone.
That I don't wanna do, as I'd potentially be making the motor unusable as a motor...even though I might be able to undo whatever I do to short the lams, I might not. :/Lacking a FOC, another way to increase the no-load heat generation inside a motor is to short together the steel laminations so that you have way higher eddie current losses in the core.
That's another one I might be able to undo...and might not.Perhaps an easier way to increase the no-load power draw is to just put a partial short circuit on one of the windings. If you scrape the enamel off the wires you can solder a bridge across some loops of copper on the core.
That'd be easier, but first I'd probably have to fix the halls in the motor, as it's likely most or all of the sensored ones I dont' presently have in use on CB2 or SBC have hall problems.If running a sensored controller, you can muck with the hall sensor timing to make it spin with extra heat. I haven't tried this but it could be as easy as putting capacitors on the hall signal lines to delay the transition timing.
Ah, but this isn't to see the stuff itself, but to watch over time as the motor does it's thing, to see if anything starts to happen to the FF or the motor or whatever, without having to take it off the stand, disassemble it and check it out.justin_le said:I hate to disappoint expectations but from my observations I think the results will be a lot less interesting than people here keep imagining from watching ferrofluid videos on youtube. From the side view there is nothing really to see, just some glistenings of oil in the very thin air gap.
auraslip said:I have another question. Would this be usable on golf cart motors? This could be another market. I don't think it'd be a good idea on brushed motors, but the RXV and IQ models use brushless motors. Heating can be a problem when loaded and traveling up hills. I could probably set up a crude test if we think it'll work.
justin_le said:As well, we've just finished potting the MXUS stator which had been modified with a plurality of thermistors separately located on the copper windings and in the stator backing.
This is a silver potting compound because it has metallic aluminum filler as the thermal conductive element. Recall from the earlier tests on this hub that we had about a 6.5 degree temperature difference between the copper and the steel/aluminum when using the FF.
https://endless-sphere.com/forums/viewtopic.php?p=1112018#p1112018
Now we'll be able to directly assess how well the potted core keeps the copper and steel temperatures uniform. Although the steady state improvements might not be too substantial, 5 degrees or whatever, the transient benefits at really high power inputs could be more significant, since then the copper heat generation can be more directly and immediately absorbed by all the steel.
fechter said:Great test.
Not too surprising that the potting doesn't make much difference since the copper is in direct contact with the iron.
A thin coat of epoxy or varnish may be all that is needed to keep the windings from moving around and help a little with heat transfer between wire strands.
amberwolf said:It'd be even more interesting if we had a transparent metal that was magnetic like the steel on the back of the magnets is, cuz then the ring/rotor could be made of that, and then the FF could be watched thru that, too. But unfortunatley transparency isn't generally a property of such metals.
amberwolf said:That's an interesting material I didn't know existed...but it appears to be a ceramic rather than a metal, and doesn't appear to have magnetic properties that could be used as the flux ring.
But I wonder if it would work for side covers.
The last might be important for whether heat can just pass thru it or if it has to be absorbed and re-radiated.Specific heat 0.781 J/(g·°C)
Thermal conductivity 12.3 W/(m·°C)
Thermal expansion coefficient ~4.7×10−6/°C
Transparency range 200–5000 nm
Punx0r said:Aside from being partly transparent at infrared frequencies, I can't see how this unobtainium is relevant to the topic?
spinningmagnets said:I believe this FF upgrade will prove to be very popular for the Leafbike-1500W and the MXUS-3000W...
justin_le said:That may be. BUT, the motors that stand most to gain from this for overall ebike useability are not so much massive motors but the _small_ hub motors that don't have the benefit of so much thermal mass for heat absorption.
johnrobholmes said:Now to root back through the thread for non potted mxus data to compare potted vs non potted copper temp.
That is awesome! I always thought air scoops would be impracticable or cumbersome, but now I've seen how you've done it, I could totally see that working well.justin_le said:[On that front, lots and lots of new test data with the MXUS motors on the way, this here is what is spinning in the wind tunnel right now.
This is exactly why I went smaller (than most) and added forced air cooling to my Leaf motor for my Stealth Fighter:justin_le said:The takeaway from all this should be that even while most DIY cooling mods on ES seem to focus on large big hubs, in many cases they don't really need it since the mass itself keeps things in check. And even though we don't see too many people modding small motors for better heat dissipation, those are the ones that could use it the most.
fechter said:That's very interesting about the heat capacity. A quick look at a table of heat capacities shows water would be better than aluminum for a given mass or volume in terms of heat capacity.
Offroader said:I thought water cooling a hub motor was one of the best methods to use?
Why isn't this looked at more here? It really isn't that hard to put some water blocks into the motor and make the side cover take a larger bearing for the water hoses.
Running a fuse hoses to some radiators on the bike isn't all that hard also.
