broke said:thinking of getting this motor can you help
1. how is the controller and throttle I was thinking of using my own lyen?
Unfortunately no, the torque is too high and if you look carefully the motor is bolted with only 2 screws !!!broke said:2.do you think you could run it on low power with the bb sheaths that come with until I can get something better?
Amazing, a long cry of pain in a dark forest !broke said:3.how is the noise?
Not so bad, anyway I had redone the chairingbroke said:4.How do the chains hold up?
Seems fine, you can find a lot of usefull informations from Karl website:broke said:5.how are the gears holding up?
spinningmagnets said:When you had the motor apart, did you measure the width and diameter of the stator?
