(Sold Out) New Domino Twist Grip Throttle
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
mistercrash   10 kW
Re: New Domino Twist Grip Throttle (Back in Stock)
Post by mistercrash » Nov 14 2015 1:23pm
Sorry for the noob question but I never had to wire a throttle before, I only had to plug it in. Which wire is which? From my controller, I have a purple wire (5V), a green wire (throttle), and a black wire (ground). If I have to guess, the Domino white wire is the ground, the black wire is the throttle and the light blue wire is 5V?
Ray
Send $10 at paypal.me/Ray1964 and you will be in my thoughts and prayers.
r3volved   100 kW
Post by r3volved » Nov 14 2015 2:00pm
mistercrash   10 kW
Post by mistercrash » Nov 14 2015 4:16pm
Thanks r3volved, but the connections that were made in those posts to a CA did not help me much with my Kelly controller. I ended up using the white wire as the ground, the black wire as the throttle, or signal and the light blue wire as 5V and it works.
inertiaproject   100 mW
Post by inertiaproject » Nov 16 2015 10:41pm
Hi Ray,
I will send you the drawing in a PM.
Thanks.
Mammalian04   100 kW
Post by Mammalian04 » Nov 16 2015 11:36pm
You still have some left inertia?
Post by inertiaproject » Nov 17 2015 1:31pm
Hi,
Yes, there are still 20 throttles in stock.
bigsi   10 W
Post by bigsi » Nov 18 2015 3:26pm
I tried to pm and it said you didn't exist?
specialized s-works enduro carbon running 18FET Lyen. crystalyte 5304v3 running 105v 15ah....
I build quick release custom batteries to any size and shape. Including custom installs.
Post by inertiaproject » Nov 18 2015 9:19pm
Hi,
Odd, I will PM you. Thanks.
bigbore   10 kW
Post by bigbore » Nov 19 2015 6:48pm
mistercrash wrote:Thanks r3volved, but the connections that were made in those posts to a CA did not help me much with my Kelly controller. I ended up using the white wire as the ground, the black wire as the throttle, or signal and the light blue wire as 5V and it works.
My throttle arrived yesterday and today I have installed it on my Bomber using the same connections as mistercrash with an Adaptto controller.
It has a nice liner output instead of the crap curve that I had with an half throttle.
The half throttle I had before:
Domino:
DasDouble   100 kW
Post by DasDouble » Nov 20 2015 4:13pm
What half throttle have you had before?
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
DasDouble   100 kW
Post by DasDouble » Nov 21 2015 7:14pm
Does the Domino supports handguards which have to be pluged into the handlebars? Like this:
-Built own ebike: ✔
Post by inertiaproject » Nov 21 2015 7:38pm
Yes,
Handlebar plugs and guards are compatible.
Thanks.
bigbore   10 kW
Post by bigbore » Nov 23 2015 2:38pm
DasDouble wrote:What half throttle have you had before?
One of these one:
http://www.ebay.it/itm/Half-twist-throt ... SwHnFV6Fsw
With this stock Bomber throttle was the same:
http://www.ebay.it/itm/121129853171?_tr ... EBIDX%3AIT
Simonvtr   100 W
Post by Simonvtr » Nov 23 2015 6:11pm
Got mine in yesterday.
Love the way it feels compared to my old hard plastic throttle and I really like how heavy the return spring is.
My old throttle was really soft and can easy be twisted during a turn.
I had to set the settings on the CA3 for 1v starting position on the old throttle but with the new Domino I was able to set it really low.
Able to wired it up fine to my CA3 and played around with the over volt settings on the throttle for it to not cut out when you have it fully engaged.
+1
Simon
bigsi   10 W
Re: (Sold Out) New Domino Twist Grip Throttle
Post by bigsi » Nov 26 2015 3:24pm
Very very fast delivery and works straight away with a ca. V3 I'm buying another. What a difference to the crap from China. Thanks mate
deronmoped   10 kW
Post by deronmoped » Dec 21 2016 12:54am
I would like to purchase a throttle too.
Thanks, Deron.
