Allex
Nice one 9lives, but 210 is la bit on a low side
9lives said:SamD, 20S pack+ MXUSv2+ Max-E at 210 phase amps = awesome fun. I'm running one of your MXUS's on my phaser and couldn't be happier. The adaptto's are not cheap but the price is quickly forgotten in terms of liveability and performance. The MXUS with aluminium stator eats up the temp spikes nicely and the only issue I have had is that the disk screws as supplied are on the short side. To get the best of the adaptto recommend matching it with a high wattage charger (I am running an Eaton courtesy of Allex on forum) and you are looking at 30 minute turnaround to charge.
ohzee said:Has anyone ever purchased just a swing arm from David ? I cant get him to respond to emails to me asking for a quote on a 150mm swingarm.
If so curious on the cost.
Great, thanks for the info. I will probably do this at some stage in the future, really like the look.wingsuit said:the seat is made of wood with some steel rods for where it attaches to the bike seat post. I wrapped it in foam, then stapled nylon around that. I also build the rear light that kind of tucks up under the seat.
at the far frontal portion of the seat, I drilled a hole in the seat and a corresponding hole in the frame and bolted it to the frame. mainly just because with that much leverage the seat could twist in the post with any side movement. this way it stays nice and solid.
I've been riding it to work which is a 30km ride. its pretty comfortable until 15-20km in, then feels like it could use a bit more padding. for normal riding though its great
korpin said:well i sold my phasor for 6,000.00 USD a lot less than what I had into it...I liked it was getting over 50 mile range but I wanted to try sine wave,a bigger MXUS motor,and a bigger battery without increasing weight too much so decided to start with lighter frame...I will post photos of my build soon here is my bike i sold
Deutch420 said:korpin said:well i sold my phasor for 6,000.00 USD a lot less than what I had into it...I liked it was getting over 50 mile range but I wanted to try sine wave,a bigger MXUS motor,and a bigger battery without increasing weight too much so decided to start with lighter frame...I will post photos of my build soon here is my bike i sold
6000$ usd!!?? Congrats!!! I can't get 2/3 that price and I have better parts across the board. Congrats man.
