bionicdan said:Getting 2x20ah 4s and 1x20ah 6s delivered tomorrow. This will be my perfect pack with a mix of size, weight and capacity I think. Hopefully no self dischargers this time. Let me know if you need any measurements of size as they have mucked up the orientation of the dimensions I think/hope.
johnamon said:Please post a few photos of everything in one shot with a reference item (tin of Coke is a good example as it's a similar shape)..... and width, height, lengths. Thanks!
miuan said:The 20C will serve you well at 1-1.5C continuous or 3C peak.
I have used my 10Ah Multistars with a 60A controller and after 4 months use the cells' capacity starts to diverge.
They will still hold top balance but became very inconsistent on bottom end, requiring a much higher LVC.
I need to retire the cells and return to my 2yr old Zippies which are much higher C and still keep perfect balance top and bottom. They are a lot heavier though.
That's somewhat disappointing for running at less than 1C. May I ask your typical charge/storage voltage?icecube57 said:After a year on the 10AH packs i saw a 5-8% loss of capacity in the packs. But i was running them in 4P and only using 25-30A on a BBS02
Marnelie11:18:59 AM
Yes, the back order item with no line that means that you just need to wait the restocking of 30 days but the back order item with line, we are not sure when will the item it will back on stock.
claire11:19:52 AM
cwah said:If you can only pull 3C max.... why don't you just get the ncr18650pf? They also pull 3c max and are lighter too!
