I will review soon some 0.2mm and greater thickness so I can update the table for greater strips and we can compare results.
My tests takes into account shrink wrap insulation and surface area for an average strip dimension, the maximum values are where the efficiency still very high (not appreciable voltage drop) and the temperature is just slightly over room temperature, and which from that point, the small increases amount of amps are noticiable exponentially increases on heat, so that's the maximum current recommended for an optimal efficiency and conductor worth.
I will also add more technical data to the tests as Voltage drop and differences in temperatures
Really good tests! thanks for sharing!
