cyclone&cannondale
jordison   10 mW
cyclone&cannondale
Post by jordison » Feb 28 2016 5:04am
hey guys
here is my old 1998 cannondale f800 converted in 2014
motor: cyclone48v
battery: 14s 15ah lipo
controler :kelly kbs
5750 milles / 9200km
the beginning
aluminium box in the frame, much beter
road trip
on a boat
old gearbox gears with 3800 milles vs new gears
gman1971   10 kW
Re: cyclone&cannondale
Post by gman1971 » Mar 07 2016 11:13am
Very nice dude!! Can you share your experience with maintenance? how is it been?
G.
I am all about high-speed, low-drag, mid-drives and gears...
A-3 trike, ?-kW, ??+ mph (Cyclone powered) Very fast, ludicrous speed fast...
A-1B trike, 6+kW, 65+mph (Cyclone powered): https://www.youtube.com/watch?v=oFC8MRwvgUM
A-2A trike 3kW, 50mph (Cyclone powered): https://www.youtube.com/watch?v=bNoqp0wl6Vo
eB-1C bike 3kW, 42mph (Cyclone powered): https://www.youtube.com/watch?v=_weSmz_h3Ig
jordison   10 mW
Post by jordison » Mar 30 2016 2:31pm
its a mid drive and its a cyclone, so there's some implied maintenance.
i replace the chains every 2000 miles, i broke 1 chain after 2600 milles.
rear cassette lasts about 4000 milles.
replaced one rear derailleur pulley
i use transmission oil in the gearbox, it´s easear to clean when i need to replace the gears.
i replaced the 48t steel chainring for aluminium, big mistake, i guess it wasn't very round and put lot of stress on the motor bearings, chain and booth freewheels.
the lipos never get out of balance, so no problem there.
i have the controller limited to 40amps
i wanted an internaly geared hub, but some are expensive and the nexus might not handle the power .
KOMAN   100 mW
Post by KOMAN » Mar 31 2016 10:48am
I have a cyclone kit.
I have problems. The engine overheats and turns off the controller.
Happens to you this problem?
you know that is?
Greetings and enjoy your bike
jordison   10 mW
Post by jordison » Mar 31 2016 4:29pm
the motor can cut the controller if you have a thermistor to send the motor temperature information to the controler.
i dont have that on mine, it happened the other day going downhill at 79,5 kph = 49,5 mph
it may not be the motor, the controller can overheat if you ride it in high rpm.
gman1971   10 kW
Post by gman1971 » Apr 01 2016 4:18pm
Pretty nice dude. It sounds like the Cyclone 3000W kit they recently released was a huge improvement over their older kits...
G.
jordison   10 mW
Post by jordison » Apr 02 2016 6:40am
the 1680w kit is not that bad.
most of the problems i had were after this piece of crap chainring, the teeth are ok , but its not perfectly round.
wanted to reduce weight and improve performance, the result was several failures
KOMAN   100 mW
Post by KOMAN » Apr 03 2016 3:22pm
The heavi cyclone kit dishes are standard.
Very good improvement, this adapter plates.
You use aluminum?
jordison   10 mW
Post by jordison » Apr 04 2016 12:57pm
yes it's aluminium.
it would be a nice upgrade, this one is not round enough, turning the crank i could feel it putting pressure on the motor freewheel
KOMAN   100 mW
Post by KOMAN » Apr 04 2016 1:01pm
You can buy online this that adapter plates.?
You can put a link?
Thank you
KOMAN   100 mW
Post by KOMAN » Apr 04 2016 3:48pm
I found this adptador
http://www.sickbikeparts.com/catalog/pr ... cts_id=163
With these dishes would be light and strong:
http://www.recambios-bici.es/1846766-pl ... -94mm.html
While the kit would cyclone with these dishes 32T?
reviews
boisrondevens   100 W
Post by boisrondevens » Apr 05 2016 11:25am
Hi
I can make custom adapter for you and what ever stiffness you want.
Pm Me
boisrondevens   100 W
Post by boisrondevens » Apr 05 2016 11:36am
Hi
I can make custom adapter for you and what ever stiffness you want. you just have to provide me with the dimmentions
Pm Me
regards
Evens
jordison   10 mW
Post by jordison » Jun 06 2017 5:12am
after about 600 cycles 2 of 6s lipo pack started to swallow, one pack had 1 cell with 3.3v and the others 3.8v.
these 2 bricks were a the bottom with all the weight on top of them , i'm not sure, maybe this killed this 2 cells.
i raplaced one of the cells from the old brick to make a spare,the outer cells are ease to replace.
i opened up one of the cells, it stinks like glue.
jonnydrive   100 W
Post by jonnydrive » Nov 30 2017 3:46am
Hi jordison,
I have a setup similar to yours: cyclone 1680 with kelly KBS-X
Unfortunately I am experiencing some trouble to set up the controller: the engine seems spin smooth but when it is connected to the bike the performance are very poor and the engine overheats after a very short time.
Had you used the "auto_identify" option during the set-up? (ref: https://kellycontroller.com/KBS-Xhelp.php)
have you experienced some similar issue? suggestion?
Can you post your controller settings? pleeees :-)
Thanks a lot
Stefano
jonnydrive   100 W
Post by jonnydrive » Dec 06 2017 3:36am
Ok,
auto_identify option of kelly controller sucks.... DO NOT USE IT!
Manual swapping hall wires resolved the problem, now the engine spin faster as expected.
I am using the KBS72121X rated for 55amp continuous, it is quite overpowered for cyclone 1680w (the engine is rated for 33a continuous) and....it is quite difficult decode kelly controller settings.
Playing with the Max battery current and Max Motor Current to limit the maximum amperage i found this:
- Max Battery Current = 100% (this setting seems to limit the max voltage not the max amperage = the engine spin low
- Max Motor Current = unlike other Kelly controller it seems to be the motor current and not the phase current (perhaps)
= 100% it means boost current (130A) for 10/30 seconds and after 55A the continuous amperage
My dumb math: 130A * 30%(Max Motor Current) = 40Amp
if you keep 100% the engine stall as soon you open the throttle.
The kelly settings now are quite similar to the original (not programmable) controller but:
  • kelly is a lot more smooth than the original controller (pro)
  • kelly provides less torque at low speed but good acceleration
  • with the same gearing (wheel:48:12, engine:53:13) with kelly, the engine overheats more easily (cons)
The gearing is for sure not ideal, the engine spin at low speed absorbing all the amperage available and wasting energy but: how it is possible that the ultra cheap Cyclone controller provides more torque at low rpm and avoid overheating compared with fully programmable 3xExpensive Kelly controller????
someone have similar experience to share?
jordison   10 mW
Post by jordison » Feb 20 2018 5:07pm
kelly's aren't known for big take off power.
i have (had) the kbs-L, it doesn't have auto identify option
i see that you have the smooth setting enabled., i would try disabling it
