Sounds like you are abusing your Multistar Batteries.
If you read back though this thread, you will see that icecube57, after extensive discharge testing, recommended a max. discharge rate of 25 Amps for Multistar. And you are over-discharging as well. At 3.7 cel/V.,the pack is done and needs recharging. In fact, most of us try and stay in the 80% depth of discharge range to maximize the service life of the batteries. Trying to use the pack with cell Voltages below 3,7V is not only an exersise in futility(there is not much there), it is flirting with disaster.
You might try removing the weak cell. I have done it with standard Lipo, but it is difficult to solder/unsolder what amounts to foil covered plastic. The Multistar uses metal tabs, and although I haven't tried, they look like they would be easier to unsolder/solder. But I suspect the damage is done, and other cells will soon follow suit.
It seems to me you need some new Lipo, and a revision of how you use it.
