Some specs of Electric Fox:
Fully electric, driven by 6 liquid cooled axial flux permanent magnet synchronous electric motors, managed by special high voltage controllers.
Custom-order lithium ion pouch cells assembled by DriveEo. The complete pack includes battery management system, insulation monitoring device, contactors and fuses from the world leading component suppliers, all of which is housed in an electrically isolated, environmentally sealed and air ventilated container.
Chassis specs are:
4130 Chromemoly Tig welded chassis exceeding SFI Spec 2.5C ( to 6.00 seconds)
245” Wheelbase, 21”– 23” Shoulder hoop width (to be decided)
Strange Aluminium 9” housing, Strange Ultra Case, 40 spline, 3.812”, Pro Gears with Coupler
Strange 40 spline Gun drilled axles, H/D bearings, 5/8” stud kit
Strange Race 2 piece Floating Rotor Brake kit, Calipers and Mounts
Streamline Aero A-arms, Strange Spindles and Arms, Stiletto Rack and Pinion
Steering Column with Safety bush, Steering Wheel with Strange Quick Release Hub
8” Adjustable Throttle and Brake pedal Assembly, Pedal stop and Throttle Cable Mount
Brake master Cylinder, Residual Pressure Valve, Fittings and Hard Line, Plumbed in
Parachute, Mount, Cable, Lever and Mountings
Aluminium Dash and Gauge Cover Panel, Aluminium Floor and Bulkhead, Rear Deflector Plate
Fiberglass seat on Dzus Fasteners, 6 point Harness FIA/SFI spec
Multi Piece Aluminium Body, Aero Lip on Bottom, Countersunk Aluminium Dzus Fasteners
Scratchproof Moulded Tinted Lexan Screen, Fiberglass Nose Piece
Exit Handles on Roll Cage, Non-slip Tape on Floor, Roll Cage Padding
Weld V Series Wheels, Front 17 x 2.5, Rear 16 x 16 Double Beadlock Ultra Light
Hoosier Tyres, Front 17 x 2.5 - 17, Rear 34.5 x 17 – 16
