case COMM_GET_VALUES:
ind = 0;
send_buffer[ind++] = COMM_GET_VALUES;
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS1), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS2), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS3), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS4), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS5), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_MOS6), 1e1, &ind);
buffer_append_float16(send_buffer, NTC_TEMP(ADC_IND_TEMP_PCB), 1e1, &ind);
buffer_append_float32(send_buffer, mc_interface_read_reset_avg_motor_current(), 1e2, &ind);
buffer_append_float32(send_buffer, mc_interface_read_reset_avg_input_current(), 1e2, &ind);
buffer_append_float16(send_buffer, mc_interface_get_duty_cycle_now(), 1e3, &ind);
buffer_append_float32(send_buffer, mc_interface_get_rpm(), 1e0, &ind);
buffer_append_float16(send_buffer, GET_INPUT_VOLTAGE(), 1e1, &ind);
buffer_append_float32(send_buffer, mc_interface_get_amp_hours(false), 1e4, &ind);
buffer_append_float32(send_buffer, mc_interface_get_amp_hours_charged(false), 1e4, &ind);
buffer_append_float32(send_buffer, mc_interface_get_watt_hours(false), 1e4, &ind);
buffer_append_float32(send_buffer, mc_interface_get_watt_hours_charged(false), 1e4, &ind);
buffer_append_int32(send_buffer, mc_interface_get_tachometer_value(false), &ind);
buffer_append_int32(send_buffer, mc_interface_get_tachometer_abs_value(false), &ind);
send_buffer[ind++] = mc_interface_get_fault();
// TODO: send FOC values id, iq, abs
commands_send_packet(send_buffer, ind);
break;
