Rev said:I have a 2nd, likely 3rd hand carbon AT. I suspect the battery might be on it last legs. I get power cut outs after about 5-7 kms of riding. Any advice on how I can test the state of the battery?
whitepony said:Rev said:I have a 2nd, likely 3rd hand carbon AT. I suspect the battery might be on it last legs. I get power cut outs after about 5-7 kms of riding. Any advice on how I can test the state of the battery?
usually with AT, you can get to 15km if you drive normal, up to 25km if you drive 18km/h nonstop on flat terrain. my guess is, you drove normally, so 5-7k means you are probably down to 50% battery capacity. time to build your own!
whitepony said:built a new pack for the evolve carbon these days! did a much better job overall compared to my very first pack, many small details are better, much better cells with the Sanyo NCR18650GA (even though the panasonic hold up well tbh).
Ill just drop some pictures here, maybe it will motivate you to make your own pack.
new bench from my granddad, fixed up with hard wood and aluminum angle for much easier and more professional alignment of up to 10 cells parallel:
work time: about 1 day!
whitepony said:its me again! as a "p.s." for the double evolve range article, I wanted to describe quickly how to build your own spot welder for ridiculously low money for pretty much professional DIY battery constructions.
most of the things were actually common knowledge from various pedelec forums - best thread ever here http://www.pedelecforum.de/forum/in...u-punktschweißgerät-für-akku-verbinder.11421/ (but its sadly in a german forum). I think I built one of the most simple version though!
Material list:
* 2F power cap (40€)
* 2x 8mm thick and 10cm long copper rods (2€)
* 20x5mm copper bar, length 30ish cm (3€)
* very thick cables, I bought 25mm^2 which was probably overkill (10€)
* 6 ring connectors (2€)
* old battery charger, charge voltage 17V
* some screws and a wood plank
Basically you use the power caps stored energy 0.5*C*U^2 (C = capacity, U = voltage), to weld thin materials together within microseconds. So all you gotta do is:
* loading up your powercap
* putting the electrodes where you want to spot weld
* connect powercap with electrodes with a switch who can take 1000-2000 ampere and unload it in fractions of a second
* start over
Most use fairly complicated and expensive electronic things to switch - thyristors, and other stuff. I went for the archaic 20x5mm copper switch version (see pictures). made the electrodes from the 8mm copper rods, drilled a hole in their back, cut in a thread and connected the ring connectors of the huge cables with screws at the electrodes.
A tip for soldering 25mm^2 cables into ring connectors: https://www.youtube.com/watch?v=zssIlnwH8dY
here you can see the full setup sort of - powercap, copper electrodes, copper switch:
and here the copper switch closeup - you can tune the gap on the left side with adding washers of different thickness on the right - if you make the gap on the left side too small, the force pulling the copper back will be too weak and it will weld together eventually.
hope this helps - its very simple, very cheap and works like a charm (this is me in action on my very first battery pack - at that point i killed one cell cause my copper switch welded together - thats when i learnt that the gap needed to be large enough - it happened never again after that, but I was cautious anyway and put together the electrodes every time for a quick check if the switch actually disconnected the powercap): https://www.youtube.com/watch?v=cfbOmuBMLZc
have fun
DaDo.Bzz said:how do you charge the cap using a laptop charger? just plug the probes in and call it a day?
do you have any sort of current limiter?
is the high voltage cap needed or can i use a bunch of small low voltage caps?
whitepony said:diagram is correct
I got a very old car battery charger from my dad - it looks like it was build 1945, very sturdy - so I connected it directly to the cap, i.e. the moment I discharge the powercap until its loaded back up, the charger is pretty much shortened. it didnt feel great, but it was also not a problem and I welded about 500 cells by now in total! you can always put a strong heavy load resistor between charger and cap, but recharging the cap will take some more patience then. its already going too slow for my taste, always takes 3-4seconds until the cap is really up in saturation again! If i weld too fast and the cap is only at 12-13V I can tell right away from the weld spots. thats cause the energy that goes through the spot depends on the square of the voltage.
no current limiter
many smaller capacitors are probably even better, because their discharge current should be even higher I guess. only important part is, that the amount of unloaded energy must be reasonable. apparently my 0.5*C*U^2 is working very well, you should probably try and keep similar values. you can vary C and U of course - smaller capacity but higher voltage should work well too! its just that I only had that 17V charger, so the cap had to be chosen accordingly!
delta_19 said:whitepony said:diagram is correct
no current limiter
OK so LV is a no go needs to be a minimum of 12v at 2 Farads. So I may get a 3F cap at BB or go the cap bank route but, either way thanks for the help.
randyc1 said:Hi Whitepony.
When you eliminate the BMS on your Evolve Carbon AT , The Charger will charge to 42V,... but what stops the battery from over Discharging ?
On my board like your DIY, the Vesc will do that job, but what about the Evolve without BMS??
Thanks .
How would I even go about the wiring for charging?
Connect plus and minus to the charger and it'll just charge all the way to 42V and then stop automatically?
Oh I was aware that there are 6s chargers as well. It just sucks that there are none on the website that whitepony posted, since those guys aren't too far away from where I live and I wouldn't have to wait a month for it to arrive (as is often the case with alibaba).randyc1 said:There are 6s chargers ! , just search for 25.2(4.2vx6) on Alibaba web site.
whitepony said:if you build a battery without a bms, you simply cannot charge to 4.2V/cell because any drift will immediatly overcharge cells.
my evolve charger stops at 4.14V per cell and I recently ordered a charger with a poti that allows me to tune the end-of-charge voltage, which is now 4.05V/cell - thats a LOT of headroom for potential drift ... and increases the lifetime of the battery!
the over-discharge is handled by the evolve carbon esc, that also cuts the power below a certain 3.XV threshold.
yea!
btw, I still cant measure ANY drift in any of my batteries! 8)
*charger with customizeable end-of-charge voltage*
