EGO and Echo have batteries that are verified to be 14S. When fully-charged they are both 57.X volts, with both charging to roughly 4.1V per cell. Each system has a family of tools that the same battery can power, such as a weed trimmer, grass mower, chainsaw, leaf blower, etc. The Snapper gardening tools have a battery pack that is almost identical to Echo, and I have not verified that the Snapper is 14S (the factory approved youtube shows 30 cells, so its likely 15S / 2P). DeWalt has a 60V line of cordless tools, but I finally found out they are 15S. Their labeled voltages are :
56V__EGO
58V__Echo
The Echo cells are clearly labeled "LGDAHD41865" there is a second row of number/letters on each cell, but they are different for each cell. The EGO cells have a secondary cover over a "phase change" sleeve for heat leveling (so the part number isn't evident in the video). I assume the phase change sleeve is similar in composition to what Allcell uses. It turns from a firm rubbery feel to a soft rubbery feel when it absorbs heat, and then firms up when it cools down.
The EGO cells are likely the 20A Sanyo UR18650RX https://endless-sphere.com/forums/viewtopic.php?f=14&t=61642#p1087645
Here's a 20-minute teardown video for the EGO and Echo battery packs.
https://www.youtube.com/watch?v=lRdBS9oFUXc
The Echo has no apparent air vents, which may be because it also has a bare BMS board. The EGO has a fully potted BMS, and it does have obvious air-vents. Also, when the EGO motor is spinning, the battery mount has a fan that actively flows air through the battery pack, very impressive design.
My interest in these has to do with the fact I that have two large ebike battery packs that are 14S. em3ev calls theirs 14S packs "50V" and Luna calls them "52V". Manufacturers often don't like customers using batteries from one vendor to power their tool, so sometimes their tools have an extra wire that sends an ID signal. By that I mean that I don't know what it would take to get a 14S ebike pack to power a cordless tool from EGO, Echo...but at this point we do know the voltages are the same.
Their entry level packs are 2.0-Ah of 1S, so the cells are 2000-mAh, and definitely medium-to-high amps. They are very impressed with themselves when they state that their big pack is 4.0-Ah. When my 17-Ah 14S pack wears to the point that I am only able to access 12-Ah of range...I can start using it on my lawn tools, and I will still be able to have three times as much run-time as their "large" pack (likely worn in a backpack).
This is all experimental at this time, do not attempt this if you cannot afford to accidentally damage your cordless tools.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Some of you may know that DeWalt has a line of "flexvolt" 20V / 60V batteries, that are 5S / 3P / 6-Ah, or can be seriesed/paralleled to 15S / 1P / 2-Ah, so when charged to 4.1V per cell, they will be at 61.5V (using 2000-mAh high-amp cells). Since the battery packs are the part that has the LVC and protection circuits, it "might" be possible to use a 14S ebike packs on a DeWalt cordless "60V" tool. If you try this and the tool shuts down way too soon, then the tool also has an LVC.
http://toolguyd.com/dewalt-flexvolt-answers/
The 60V Snapper tools have a youtube that indicates there are 30 cells, so its likely 15S / 2P
56V__EGO
58V__Echo
