How to connect Cycle Analyst to Kelly Controller?
- smeagol222 100 W
I heard a special plug might be needed? I really dont want to open up the controller and solder things around
like this http://www.ebikeschool.com/add-cycle-an ... ontroller/
product page: http://kellycontroller.com/keb72601x24v ... p-279.html
user manual: http://kellycontroller.com/mot/download ... Manual.pdf
First project small E-scooter upgrade 3kw 48v 45a https://endless-sphere.com/forums/viewt ... 12&t=86228
Current project medium E-scooter upgrade 8kw 72v 100.5a https://endless-sphere.com/forums/viewt ... 10&t=85164
Re: How to connect Cycle Analyst to Kelly Controller?
No need to open the controller. Use an external shunt wired something like this:
If you are running 50-60A battery continuous current or less, you can use the more compact molded external shunt instead and just wire it as described in the Guide - just wire either fat red Vbatt+ wire from the molded shunt to pin 1 (PWR) above instead of to the battery as illustrated in the Guide - the other fat red wire can be left disconnected.
This is the wiring for a CA3 where the throttle and ebrake go to the CA. The CA2 hookup is identical except for the throttle/ebrake - see the CA3 Unofficial Guide 'Appendix D. Adding a CA-DP Connector to a Generic Controller' for details.
- smeagol222 100 W
Good to know- thanks for this info. I also confirmed with kelly controller also
they said below and gave me this PDF
All the wires are outside of the controller.
They are located on the J2 cables.
All the wires are soldered on the J2 cable and got a 6pin SM connector finally for CA connector.
- Attachments
KEB KBL with CA.pdf
- (23.53 KiB) Downloaded 330 times
- smeagol222 100 W
I thought that for my use CA was a bit of an overkill. $20CAD dc voltmeter/ammeter should do the trick
Does this makeshift circuit diagram look right?
no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
Wire the (+) connection as shown in the diagram above to pin 1 (PWR) so the keyswitch turns off the display...
- smeagol222 100 W
ah nice spot, will do thatteklektik wrote:no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
Going to use the smart precharger also
http://www.zeva.com.au/Products/datashe ... erV1-3.pdf
I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?smeagol222 wrote:ah nice spot, will do thatteklektik wrote:no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
How is the smart precharger working for you?
Sorry about so many questions. I'm still on the steep learning curve.
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
My builds:
- smeagol222 100 W
Hey I'm just starting out with this build, currently waiting on the battery to shipEcyclist wrote: I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?
All the details here: viewtopic.php?f=10&t=85164
Thank you and please keep us posted.smeagol222 wrote:Hey I'm just starting out with this build, currently waiting on the battery to shipEcyclist wrote: I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?
My builds:
My builds:
