How to connect Cycle Analyst to Kelly Controller?
- smeagol222 100 W
I heard a special plug might be needed? I really dont want to open up the controller and solder things around
like this http://www.ebikeschool.com/add-cycle-an ... ontroller/
product page: http://kellycontroller.com/keb72601x24v ... p-279.html
user manual: http://kellycontroller.com/mot/download ... Manual.pdf
First project small E-scooter upgrade 3kw 48v 45a https://endless-sphere.com/forums/viewt ... 12&t=86228
Current project medium E-scooter upgrade 8kw 72v 100.5a https://endless-sphere.com/forums/viewt ... 10&t=85164
Re: How to connect Cycle Analyst to Kelly Controller?
No need to open the controller. Use an external shunt wired something like this:
If you are running 50-60A battery continuous current or less, you can use the more compact molded external shunt instead and just wire it as described in the Guide - just wire either fat red Vbatt+ wire from the molded shunt to pin 1 (PWR) above instead of to the battery as illustrated in the Guide - the other fat red wire can be left disconnected.
This is the wiring for a CA3 where the throttle and ebrake go to the CA. The CA2 hookup is identical except for the throttle/ebrake - see the CA3 Unofficial Guide 'Appendix D. Adding a CA-DP Connector to a Generic Controller' for details.
- smeagol222 100 W
Good to know- thanks for this info. I also confirmed with kelly controller also
they said below and gave me this PDF
All the wires are outside of the controller.
They are located on the J2 cables.
All the wires are soldered on the J2 cable and got a 6pin SM connector finally for CA connector.
- Attachments
KEB KBL with CA.pdf
- (23.53 KiB) Downloaded 331 times
- smeagol222 100 W
I thought that for my use CA was a bit of an overkill. $20CAD dc voltmeter/ammeter should do the trick
Does this makeshift circuit diagram look right?
no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
Wire the (+) connection as shown in the diagram above to pin 1 (PWR) so the keyswitch turns off the display...
- smeagol222 100 W
ah nice spot, will do thatteklektik wrote:no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
Going to use the smart precharger also
http://www.zeva.com.au/Products/datashe ... erV1-3.pdf
I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?smeagol222 wrote:ah nice spot, will do thatteklektik wrote:no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
How is the smart precharger working for you?
Sorry about so many questions. I'm still on the steep learning curve.
Don't expect from life to be easy and then it will be.
My builds:
Avian with hypocycloidal drive https://endless-sphere.com/forums/viewt ... 2#p1318056
2016 GNG extreme drive https://endless-sphere.com/forums/viewt ... 28&t=82252
My builds:
- smeagol222 100 W
Hey I'm just starting out with this build, currently waiting on the battery to shipEcyclist wrote: I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?
All the details here: viewtopic.php?f=10&t=85164
Thank you and please keep us posted.smeagol222 wrote:Hey I'm just starting out with this build, currently waiting on the battery to shipEcyclist wrote: I like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?
My builds:
My builds:
Guys, when I connect "hall A" to "Yel spd 5" on CA3 the hall stops working, upon disconnection of this wire it works again. How to solve this issue? Tried other halls with same issue. Interesting that on another bike with same controller and motor it works but CA on that bike is really old, one of the first ones.
Solved this with connecting diode between hall A" and "Yel spd 5"
Join Endless-Sphere Telegram group: https://t.me/endless_sphere
Sur-Ron Dealer Europe SE
Sur-Ron Dealer Europe ENG
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
viewtopic.php?f=4&t=37964&p=1622308#p1622308
If not, then whatever si wrong is whatever the difference in setings and or wiring.
Which one? there are several on that threadAllex wrote: ↑Mar 03 2021 3:36pm
Now to another issue. When connecting ca using this schematics:
viewtopic.php?f=2&t=84739
is the other ca setup with exaclty the same settings and exactly teh same wiring?When I connect "hall A" to "Yel spd 5" on CA3 for it to able to read speed, the hall stops working, upon disconnection of this wire it works again.
When connecting a diode in line, halls works fine but still no speed reading.
Upon connecting another CA the speed works fine and halls works even without a diode as it should be! What could it be?
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
Just to jump in with a comment.Ecyclist wrote: ↑Dec 05 2016 12:36pmI like your streamlined set-up. I'm in the process of my second build and I would like to make it as compact as possible. Not using CA3 is one of my goals. Can you post what size of the motor and Kelly controller you are using? Do you get smooth acceleration?smeagol222 wrote:ah nice spot, will do thatteklektik wrote:no.smeagol222 wrote:Does this makeshift circuit diagram look right?]
I have been using one of these pre chargers for a year now and it is fine.
Does exactly what it should and I have never had a problem.
5p20s battery pack into Sabvoton 96120.
Pre charger is run 12v via dc/dc and powers a 200amp 12v solenoid.
