QS Motor Factory News - Racing Electric Motorcycle with QS 14kw motor 160km/h 96v
Purchase Link on Alibaba:
Motorcycle:
https://tzquanshun.en.alibaba.com/product/60604346645-804214765/2017_New_High_Power_14000W_Wheel_Hub_Motor_96V_160KPH_KTM_Adult_Electric_Motorcycle.html
Motor kits:
https://wholesaler.alibaba.com/product-detail/QS-14000W-160kmh-96V-Hub-Motor_60606565929.html
Specification:
1. Motorcycle Model: SIA-14KW(Pure Electric Motorcycle for Racing)
2. Motor: QS Motor 17*4.5inch 273 14000W 80H V3 Water Cooled Electric Motorcycle Hub Motor
3. Controller: Kelly KLS96601-8080I Sine wave controller
4. Disc Brake System: Double hydraulic disc brake for front & Benelli hydraulic disc drake for rear, by hand control
5. Motorcycle Performance:
Max. Speed(Km/h): 150-160Km/h@96v, 120-130Km/h@72v
Climbing ability: It could continues climbing 300m length slop on 16-17 degree, max. climbing 20 degree.
Heating phenomenon: When this motorcycle continuous climbing 17 degree slop for 700m, the motor basically don’t have fever phenomenon.
Consume/100KM: ≤3.5 kw/h
Distance: 96v 80ah battery charge one time driving in 160km @ 160km/h, 200km @ 100km/h.
Recharge Cycles (times): 800 times for Lithium battery, 300 times for Lead-acid battery.
Charging time: Depends on the battery type & capacity
6. Motorcycle Net Weight: 195KG(including battery and charger)
7. Loading weight: 130KG(two people)
8. Front & Rear Tire: 150/60-17&140/60-17
9. Front Absorber: Inversion Absorber(Adjustable)
10. Water cooling system:
Include Water inlet pipe & Water outlet pipe, Water tank, Water pump, Radiator...
11. Color: Cream- colored
12. Motorcycle size: 2030mm*780mm*1070mm
13. Package: Divided into two parts,
Part 1. Scooter without handle bar. Size: 2050mm*600mm*1100mm.
Part 2. Front wheel rim, Front&Rear foot rest, Rear mudguard and Battery box. Size: 1750mm*550mm*860mm.
14. Advantage: High Speed& Power, With Water cooling system, Unique design, Special and Novel appearance, Better safety performance
15.
Quotation FOB Ningbo: USD4188/piece (without battery and charger)
16.
Produce Time: 60 Business Days after receiving payment.
17.
Payment Term: Only accept 50% TT in advance for deposit, balance should be paid before shipping.
