Nyx frame, 273mm*40m V3 hub, and 650A
Hyena   100 GW
Re: Nyx frame, 273mm*40m V3 hub, and 650A
Post by Hyena » Mar 06 2017 10:59pm
liveforphysics wrote:I built it for riding single-track, and the power demands will be so much less off road it shouldn't have any thermal concerns. If it does have thermal drama off-road, FF and hubsinks should meaningfully help.
Yeah you will have no thermal dramas single tracking it!
You may have to get creative to make the existing hubsinks fit due to the larger diameter but even FF alone should take care of it.
Even 10kw is too much most of the time on singletrack - as soon as you open the throttle you're instantly teleported towards the nearest tree at a rapid rate of knots and then hard on the brakes again. It's great fun to ride at the limit like that, but it's the limit of the trail, not the motor :)
Sketch and I rode some gnarly single track doing all the worst things you can to kill a hub motor - steep uphill climbs, switchbacks, low speeds, powering hard out of twisty turns dumping many kw straight into the windings at the motors least efficiency and with hubsinks and FF even mxus motors at 10+kw remained amazingly cool (we took IR temp readings at the top).
I really need to get the video uploaded because it's a great testimonial to what sort of punishment these motors can take with this cooling methods.
www.HyenaElectricBikes.com
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Mar 07 2017 1:01pm
Good stuff! Can't wait to see it up and running! Man, belt drive AND schlumpf drive?!? Sounds like a dream bike! :D Very curious how your battery will be set up, guessing LiPo?
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
multifrag   100 W
Post by multifrag » Mar 08 2017 7:58am
Impressive build! Can't wait to see it finished. The only part I'm a bit concerned is your tire choice. Having a lot of power at the wheel but wasted through the tire because of lack of grip is not ideal, specially for 1/4 mile.
liveforphysics   100 GW
Post by liveforphysics » Mar 08 2017 9:55am
multifrag wrote:Impressive build! Can't wait to see it finished. The only part I'm a bit concerned is your tire choice. Having a lot of power at the wheel but wasted through the tire because of lack of grip is not ideal, specially for 1/4 mile.
On this short of a wheelbase, I have a strong hunch wheelies and flipping over backwards is a greater concern than the tires traction. Deathbike is long enough that you really do need a grippy tire.
fechter   100 GW
Post by fechter » Mar 08 2017 10:29am
How about using a MEMS gyro tied into the throttle for automatic wheelie control? Sort of like a Segway.
steveo   1 MW
Post by steveo » Mar 09 2017 10:02am
100% on that luke, i completely overlooked the wheelie part...
to be honest, this was one of my top concern when i built my bike. I really wanted a Nyx bike, but the cost of that frame, and having to make a custom swing arm was over my budget. I did contact NYX if they would build a custom swing arm, but they would not. So i contracted a friend of mine that was into metal working for the custom swing arm.
If you can't put the power down, all that power is useless!
My front tire just comes off the ground slightly.. and believe my my swing arm is really long. My biggest problem is my ass staying on the seat during WOT pulls. You should know what i mean by this on Deathbike lol
-Steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
fechter   100 GW
Post by fechter » Mar 09 2017 3:42pm
steveo wrote: My biggest problem is my ass staying on the seat during WOT pulls. You should know what i mean by this on Deathbike lol
-Steveo
This might help:
steveo   1 MW
Post by steveo » Mar 09 2017 5:24pm
-Steveo
This might help:
would work like a charm probably, it will make me feel like i'm 100yr old :mrgreen:, not that there is anything wrong with that LOL
Repair Thread
Doctorbass   100 GW
Post by Doctorbass » Mar 09 2017 11:16pm
To make a swing arm extension especially on the NYX bike frame is really simple. The swing arm on these frames are like flat bars.. witch is much more easyer than many other to attach extension to these! I mean who can not make a mecanical extension on a flat bar! :lol: and then you correct the angle of the rear shock and that's it
That frame is so strong it could hold a 75-7 motor right on the front of swing that arm! just like the deathbike was!
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
toolman2   1 kW
Post by toolman2 » Mar 10 2017 7:11am
steveo wrote:at 650 phase amps burst, i say 2-3 drag runs before you will feel motor saturation with no cooling installed.
will you be doing any cooling mods to the motor?, or you going to break in the winding a bit, then think about adding it later :twisted:
Any hub motor i've tried will usually start to feel power loss around 100-120c.
Very cool build, well done luke, i wish you all the best with achieving your 650phase amp ebike build!
If a motor is saturated it will happen the second (excessive) current hits the coils, from what i have tested it does not change greatly with temperature.
Sometimes the magnets are not up to the job with temperature, but they don't usually suffer as they don't get as hot as the coils. Im curious what is might be that you have noticed though? -i know the copper losses are a big player with temp -as they almost double from 10deg c to 150deg.
BTW nice bike Luke, this big diameter motor at 40mm width is an awesome and much needed step forward in hub motor design that more folks should be looking to get their hands on. -and in the 100kph+ speed range would likely be able to OUTPUT say 15-20kw ish that i don''t think folks would ever get to see with the much famed 200mm Cro/Mxus type hubbies.
steveo   1 MW
Post by steveo » Mar 10 2017 9:08am
Doctorbass wrote:To make a swing arm extension especially on the NYX bike frame is really simple. The swing arm on these frames are like flat bars.. witch is much more easyer than many other to attach extension to these! I mean who can not make a mecanical extension on a flat bar! :lol: and then you correct the angle of the rear shock and that's it
Doc
For Lukes application this is possible, with my motor it would of been simply to "fat".. you know 60mm dual winding stator and all .. with moped 13" tire :mrgreen:
Repair Thread
steveo   1 MW
Post by steveo » Mar 10 2017 9:26am
I don't know the exact technical reason, but motor surpasses 100 degress +/- i start to feel my WOT launches slow down a bit... still fast.. but slower :roll:
motor cools down, power is back up for the first couple WOT.. then repeats etc..
Repair Thread
Doctorbass   100 GW
Post by Doctorbass » Mar 10 2017 12:00pm
steveo wrote:I don't know the exact technical reason, but motor surpasses 100 degress +/- i start to feel my WOT launches slow down a bit... still fast.. but slower :roll:
Steveo, when the winding temp is high the electric resistance become high. So the max phase current drop ad voltage is near constant. :wink: The max current you can dump to a motor winding is limited by the dc resistance the phase have.
That's also why when some controller mosfet blow, this happen often when motor is cold at the begining of the ride... when the fets have to fight some low winding resistance!!
Doc
steveo   1 MW
Post by steveo » Mar 10 2017 12:07pm
very good info there Doc, well said sir!
Repair Thread
macribs   1 GW
1 GW
Post by macribs » Mar 10 2017 12:32pm
Steveo have you considered artificial cooling of some sort? Either a carbon copy of perforated sides and scoops like John in CR, fan forced frappé, Ferrofluid or oil bath? As temp is lowered so is the resistance of wires, copper etc. Also the rise of resistance is kind of bad spiral. Heat produced makes resistance increase, to make similar power you need to dump even more current into motor. Pushing your controller further. The added push from controller with the increased resistance makes more of the power turn into heat and temp rises even higher; and so does resistance.
John in CR   100 GW
Post by John in CR » Mar 12 2017 11:32pm
macribs, no "scoops" on my motors. In fact the centrifugal fan blades function in exactly the opposite manner by flinging air away from the blade tips to create a low pressure region behind the blade and suck air from inside the motor just like any centrifugal fan. ie the blade side is the exhaust side of the motor.
macribs   1 GW
1 GW
Post by macribs » Mar 13 2017 3:14am
I stand corrected. I blame that one on the last pour of scotch friday night :wink:
Point still stands, your solution worked well for you, correct?
Post by liveforphysics » Mar 13 2017 5:32am
So close now...
Rix   100 GW
Post by Rix » Mar 13 2017 7:58am
That is sick Luke, going to rip for sure!
Wheazel   10 kW
Post by Wheazel » Mar 13 2017 9:40am
So what's left to fix?
ridethelightning   1 MW
Post by ridethelightning » Mar 14 2017 4:57pm
rear disc for 1.. :D
macribs   1 GW
1 GW
Post by macribs » Mar 14 2017 5:06pm
Regen for the win :wink:
Have you worked out what controller to use?
Post by liveforphysics » Mar 14 2017 6:20pm
Wheazel wrote:So what's left to fix?
More hours in a day and more days in the week. Just got back from Italy and Germany, and heading out to Shanghai and then Taipei in a few days.
My consulting business is raining work globally right now, and I'm loving traveling the world and helping remove any obstacles from mass global EV use.
John in CR   100 GW
Post by John in CR » Mar 15 2017 12:19am
liveforphysics wrote:... I'm loving traveling the world and helping remove any obstacles from mass global EV use.
You're the man! The more EV's in use, the cheaper and better batteries will become, and beyond my own selfish reasons wanting that, it will make the world a better place.
Doctorbass   100 GW
Post by Doctorbass » Mar 15 2017 12:20am
Next project suggestion for you Luke! : Building an electric plane faster and more energy efficient than Solar Impulse for your travel !
Doc
