fechter wrote:Tornados can help with tree removal.
E.S. Quotable Quotes !
- Dauntless 100 GW
Re: E.S. Quotable Quotes !
- Arthur C. Clarke
- Arthur C. Clarke
- Dauntless 100 GW
nutspecial wrote:It's also the first time I've seen someone quoting their self, quoting their self, quoting their self. Everything has now lost meaning as if falling into a paradoxical moon bathed wormhole in the pantry.
- Arthur C. Clarke
- Arthur C. Clarke
Came to post the same quote, beat me, but it's a great one IMO.
nutspecial wrote:It's also the first time I've seen someone quoting their self, quoting their self, quoting themself. Everything has now lost meaning as if falling into a paradoxal moon bathed wormhole in the pantry.
Hilarity!dogman dan wrote: Cold and plastic can be interesting. I once climbed a very tall mountain, and got out a PVC plastic poncho, to make enough shelter to roll a joint to smoke on top. When I opened up the poncho, it shattered into pieces the size of a postage stamp and blew away.
- Dauntless 100 GW
DAND214 wrote:I sure hope you get this paradise done, before you have your stroke![]()
Dan
- Arthur C. Clarke
- Arthur C. Clarke
- Dauntless 100 GW
No, he likes ALL trolling.amberwolf wrote:So it took you THREE THREADS for the same thing to decide to listen to what people were telling you?
Do you just like trolling by dragging out replies from people?
- Arthur C. Clarke
- Arthur C. Clarke
- LockH 100 GW
- Location: Ummm.. Started out in Victoria BC Canada, then started to move around... Oh oh.
Hehe...
https://endless-sphere.com/forums/viewt ... 6#p1270399Debunker wrote:... so the big idea is settle the e-bike to gay-mode in the city (PAS and the lower power mode) and switch to full power for off-road fun.
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
- LockH 100 GW
ES Bible "No suitable matches were found." For phrase "uphill flow". Heard from GARY FISHER in a video interview about ebikes:
https://endless-sphere.com/forums/viewt ... 0#p1270722
- Dauntless 100 GW
Sunder wrote:You know, tribal leaders in rural Pakistan said pretty much exactly the same thing, when laws prohibiting honour killings were imposed on them.flat tire wrote:In this case following the law is WRONG so following the law is not what is important. You have no ethical obligation to follow stupid laws
Good to see your maturity of thinking is at the same level.
- Arthur C. Clarke
- Arthur C. Clarke
- Dauntless 100 GW
https://endless-sphere.com/forums/viewt ... 2#p1289178
AF7JA wrote:I read that article. I think the article is better summarized as "the technology, and infrastructure, for the elimination of fossil-fueled vehicles will be present within eight years." That makes for a far less sensationalistic article; but I suspect it will be more accurate.
- Arthur C. Clarke
- Arthur C. Clarke
Chalo:
It's a normal bicycle at the moment, which means that putting a front wheel drive on it makes it ALL WHEEL DRIVE. That is, assuming the rider isn't just a useless sack of fail.
Warren wrote:... wondering what the hell I was doing. Hey! I'm retired. I don't need to know what I'm doing.
d8veh:
"All the knowledge is here in the forum. Just tell us what you want to achieve and we'll tell you why you can't have it."
- Dauntless 100 GW
liveforphysics wrote:Burning things most certainly has a known outcome.
- Arthur C. Clarke
- Arthur C. Clarke
- DrkAngel 100 GW
Just use care when nailing cells together!latecurtis wrote:However even if I do order the LiPos I will still be building a large LIFEPO4 pack also as I KNOW I have the woodworking skills needed to accomplish it.
A little learning is a dangerous thing;
Drink deep, or taste not the Pierian spring:
There, shallow draughts intoxicate the brain,
And drinking largely, sobers us again.
I enjoy enlightening ... and enlivening the spirit of the innovators.
New & Improved - Acronym Definitions
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
Sometimes it works...DrkAngel wrote: Just use care when nailing cells together!
- DrkAngel 100 GW
latecurtis wrote:No. I did not know that.Seems like you cut off the pedal chains on most every bike, then struggle to ever get one put back on.
You do know that you don't have to cut the chain to remove the rear wheel ... don't you?![]()
- LockH 100 GW
- Dauntless 100 GW
I'll take two of those $5 fake Hondas.
- Arthur C. Clarke
- Arthur C. Clarke
- Dauntless 100 GW
- Arthur C. Clarke
- Arthur C. Clarke
- Dauntless 100 GW
- Arthur C. Clarke
- Arthur C. Clarke
Toorbough ULL-Zeveigh wrote: ↑Jan 04 2018 8:54pmdoughnut 4get 2pull UP on your shoe laces to lighten the load. every little bit helps.
what goes around comes around
Member #5. Crashed. Railroaded. Returned. www.tinyurl.com/welchbrief. Repeat.
