Lilium Jet
Things that fly
LockH   100 GW
Lilium Jet
Post by LockH » May 16 2016 6:29am
"This electric jet can take off vertically but drives like a car"
http://www.techinsider.io/this-electric ... car-2016-5
With zero emissions and zero runway, the Lilium Jet will be the world’s first entirely electric jet capable of a vertical takeoff and landing (VTOL). Able to fly up to an altitude of about 9,800 feet, the two-person airplane will have a cruising speed of 180 mph, a maximum speed of about 250 mph, and a range of 300 miles. At the forefront of functionality, the environmentally conscious conveyance will also be able to fold back its wings and be driven as a car.
Morning rush hours may nEVer be the same...
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
Warren   100 kW
Re: Lilium Jet
Post by Warren » Apr 20 2017 2:29pm
flathill   100 kW
Re: Lilium Jet
Post by flathill » Apr 21 2017 2:10pm
Damn zee Germans beat Joby to the punch
Hillhater   100 GW
Re: Lilium Jet
Post by Hillhater » Apr 21 2017 4:52pm
.........., the environmentally conscious conveyance will also be able to fold back its wings and be driven as a car.
But currently its just a 10mtr fixed wing , unmanned drone aircraft with a shitload of motors that flys for a few miniutes. ! :roll:
...so what is new here ?
nutnspecial   1.21 GW
1.21 GW
Re: Lilium Jet
Post by nutnspecial » Apr 21 2017 5:33pm
It runs on "Lilium"?
dirkdiggler   10 kW
Re: Lilium Jet
Post by dirkdiggler » Apr 22 2017 1:03am
I think the ehang is going to be the future. Who needs huge wings or the ability to drive when you have easy vertical take off and decent speeds flying? Will it fit in my garage?
TheBeastie   1 MW
Re: Lilium Jet
Post by TheBeastie » Apr 22 2017 11:20am
Well it looks real cool and it also greatly captures the imagination of most folks who don't think a single thing about this being possible or not unless its forcibly shoved into their face.
Looking at the massive amount of views this has got for only been up for a day is proof enough that this is something folks see as completely new and outside the box of what they thought they would ever see.
I was going to post this in my 1MWh battery pack but wont now.
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
craneplaneguy   10 kW
Re: Lilium Jet
Post by craneplaneguy » Apr 23 2017 9:23am
The video would be more impressive if they had a payload. Lot's of aircraft fly well when empty I suppose.
Fixed wing is still, and likely to continue, to still be the most cost effective way to fly from an energy efficiency POV. The most promising designs I've seen using electric flight is the concept of many small motors mounted along the leading edge of the wing, adding up to the required total horsepower needed to get the job done. BUT by subjecting the entire length of the wing to the prop thrust, they get added lift, induced lift, that's the idea anyway. Not vertical take off but real short, and a lot more practical then the huge energy demands off taking off straight up. Any aircraft needing just 2 or 3 hundred feet is way better then one needing a couple thousand, obviously I guess, but getting it down to vert takeoffs and landing sure adds a lot of complexity and power requirements, which means reduced payload and range as there is no free lunch in aviation.
LockH   100 GW
Re: Lilium Jet
Post by LockH » Apr 23 2017 12:19pm
Maybe look to the past? Me trying to interest my neighbours in repositioning an old downtown airport "GTA Aeroship (Sightseeing by Zeppelin):
http://urbantoronto.ca/forum/threads/gt ... lin.21169/
In this new century running on fear and ignorance, the idea didn't "fly". [grumble grumble] [sigh]
helno   1 W
Re: Lilium Jet
Post by helno » Apr 24 2017 7:51am
I feel like this video is not being entirely truthful.
The shots of it taking off show it lifting off of a small platform. The rest of the overhead shots it is missing.
I'm guessing it is capable of hovering but the rest looks a bit to tidy for an actual test flight.
