15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179-199
ScooterMan101   10 MW
Re: 15/18F Silent Controller 36-150V BT-iOS-Android/GPS-$179
Post by ScooterMan101 » Apr 25 2017 12:52am
For use on RC Motors ?
What KV , at What size pack ? ( 6s/7s/8s )
Just for reference as the , exact RC Motor has not yet been bought .
Powervelocity.com wrote:50K
Ecyclist wrote:What is max erpm this controller can handle?
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
fechter   100 GW
Post by fechter » Apr 25 2017 8:25am
RC motor would need to have hall sensors.
botz244   10 W
Post by botz244 » Apr 25 2017 9:59am
shipping to 99517 for an 18 fet ca3 connector,bt please. pm me thanks
bigdeezs   100 µW
100 µW
Post by bigdeezs » Apr 28 2017 1:17pm
Update 6/27/2016
You asked for it - we delivered. Variable regen is now an option on this controller.
We are working out details and they will be available soon
Any details on the variable regen as of yet?
maanebedotten   100 W
Location: A deserted island off the western coast of Norway
Post by maanebedotten » Apr 29 2017 8:44am
Do you have any pics of the alarm/gps module? Is it a single box connected to controller?
The alarm would of course be a deterrent, most thieves would probably give up and walk away if it starts screaming. But if not many people around, would the thief not try to find the box that is making noise and just remove it? Thereby also removing the tracking even though he did not even know it was a tracker?
Powervelocity.com   10 kW
Post by Powervelocity.com » Apr 29 2017 1:44pm
It has two separate boxes: alarm that interfaces directly with the controller and a GPS+GSM module that interacts with the alarm box. There is also a horn wired to the alarm box.
I see your logic and, as a security professional by trade, I can tell you that it is close to impossible for any security measure to stop a determined thief/criminal. The key word is "determined" which means that a criminal has unlimited resources in terms of knowledge, available technology, and time to defeat your security systems. If we are talking about government-sponsored criminals that mount attacks against other countries, they are likely to have those resources available. However, if we are talking about a random bike thief by Walmart, chances are he or she will not have those resources. As you have noted, there is a deterrent factor that will probably scare off most of the technically illiterate thieves. However, the GPS/GSM module will also immediately send a text to your phone the moment someone touches your bike. That shortens the time for a thief to try to disable the alarm and steal your bike. The GPS/GSM module also has a built int backup battery that will run for 24 hours even if the main power is cut. A thief has to have prior knowledge of that to avoid being located an arrested by police that you would want to call on such occasion.
maanebedotten wrote:Do you have any pics of the alarm/gps module? Is it a single box connected to controller?
maanebedotten   100 W
Post by maanebedotten » May 01 2017 11:32am
What is the wire gauge used for battery and phase?
maanebedotten   100 W
Post by maanebedotten » May 01 2017 11:46pm
Is it possible to get beefier wires on request?
cwah   10 GW
10 GW
Post by cwah » May 14 2017 6:20am
Are you able to sell it as a kit with waterproof throttle and waterproof connectors such as the Higo ones?
Help me find my stolen electric brompton: http://bit.ly/1a0vbBC and Bosch Sinus B3 http://bit.ly/1eV0WQz
Post by Powervelocity.com » May 14 2017 1:37pm
Any connectors can be retrofitted. Most hall throttle will work in the rain, just don't submerge them. However, adding extra waterproofing is not a problem. Some hi-end throttles like Domino conforms to IP67 water/dust protection. I am selling those as well.
cwah wrote:Are you able to sell it as a kit with waterproof throttle and waterproof connectors such as the Higo ones?
cwah   10 GW
10 GW
Post by cwah » May 14 2017 3:21pm
Could you provide them with right connector if I buy the throttle and variable regen throttle together?
What connector do you use? Do you also sell high efficiency motor?
I just need a kit that is RELIABLE even in london shit weather with lots of rain.
I'm planning to change everything needed to reach reliability
Post by Powervelocity.com » May 14 2017 7:55pm
I need to know a bit more about your set up to recommend anything about motor, etc. Maybe PM me and we'll see what needs to be done.
cwah wrote:Could you provide them with right connector if I buy the throttle and variable regen throttle together?
longwise_suck   10 W
Post by longwise_suck » May 15 2017 10:36am
Is there any way the soft enable/disable can be intergrated into the bluetooth program for the 18f?
Post by Powervelocity.com » May 15 2017 3:46pm
It is already there in the new version of Android app and will be available in iPhone app in a bit.
longwise_suck wrote:Is there any way the soft enable/disable can be intergrated into the bluetooth program for the 18f?
DanGT86   10 kW
Post by DanGT86 » May 15 2017 10:20pm
You have Domino throttles in stock? How much are they? Only saw the magura one on your site.
longwise_suck   10 W
Post by longwise_suck » May 16 2017 6:25am
Powervelocity.com wrote:It is already there in the new version of Android app and will be available in iPhone app in a bit.
I hadn't seen there was an update I'll check more often the new one works a lot better For me than the old one, is the soft start the check box?
Post by Powervelocity.com » May 16 2017 11:23pm
Here is the new version.
http://powervelocity.com/index.php?cont ... achment=28
The additional settings are enabled with long press on the regen ON button in the programming interface. Also, voice prompts are added for convenience.
cero   10 mW
Post by cero » May 31 2017 1:30pm
Hi
Can I reprogram controller to run the motor without hall sensors?
ecross   1 kW
Post by ecross » Jun 01 2017 6:49am
Hi Fad,
ok, on 24FET no return, so out off stock?
-so I will order one 18FET controller now
-with DC-DC 25,00
-with CA-connector 10,00
-please with this settings:
-use: 24S16P Sanyo
-LVC: 60V
-Regen: 100V
-Regen: very strong
-have a brake switch on handle bar!
-battery: 99A
-phase: max.
-please send short return!
BR
NC 2805 mod.
H4080 mod.
4504 mod.
4503 mod. with watercooling
LiIon 24S16P from Sony, Sanyo, Panasonic
Siemens 2000W travel charger
Post by Powervelocity.com » Jun 01 2017 8:31pm
If you want to run 99A and 24s (100.8v), I would recommend you wait for 24F. I am getting them back in stock in week or so. It will be worth the wait.
ecross wrote:Hi Vad,
-with DC-DC 25,00
-use: 24S16P Sanyo
-LVC: 60V
-Regen: 100V
-Regen: very strong
-battery: 99A
-phase: max.
BR
