arthurtuxedo
Desired max speed: 30 MPH under hard pedaling
Desired range: 15 mi @ 20 MPH
Donor bike: Touring road bike
Desired bike weight after conversion < 40 lbs
Desired brake type: Disc
Rider weight: 185 lbs
Terrain: Mostly flat with occasional steep hills of 20%+ grade
Budget: ~$1,200
I bought my first Ebike a few weeks ago and have been enjoying the imperviousness to wind and inclines. I was riding a pedal-only Brompton every day for 13.5 miles with some gnarly San Francisco hills, and my knees, hips, and lower back were not happy about it. I picked up a used X-Treme XB-300 Li and found it to be a huge help, but soon wanted something significantly lighter and more powerful. I realize that these two characteristics don't usually go together, but I have my reasons.
I would like to build a bike that is as close to 35 lbs as possible, as I believe that is the max weight I will be willing to carry up a flight of stairs on a daily basis. The XB-300 is about 55 lbs, so I have been locking it up outside in some very shady neighborhoods, albeit in daylight and for short periods of time. I'd like to stop doing that and also quit lugging around the heavy U-lock everywhere I go.
I would also like to be able to hit 30-35 MPH with the motor doing its work and me adding another 300-500 watts pedaling. This is because bike lanes in SF are not respected and are frequently blocked. Some streets don't have enough clearance to ride separated from traffic without getting doored. The XB-300 travels too fast to exploit a gap in traffic without having to slam on the brakes but is too slow to merge into the traffic lane without getting run over. I need something that can quickly get up to traffic speeds so I am not stuck waiting for a long line of cars to pass every time an Uber driver decides to block the bike lane (ie constantly). I'd like to be able to do 35 since a lot of drivers reflexively speed up and try to cut off cyclists who are merging into their lane ahead of them.
For a donor bike I was thinking something along these lines: http://www.bikesdirect.com/products/gravity/disc-brake-road-flat-bar/avenuefxd-disc-brake-bikes.htm
It would be sufficiently light weight, has straight bars for comfort, disc brakes, and a CrMo steel fork. I would swap out the gears for a Shimano Nexus or Alfine IGH. I got used to an IGH on the Brompton and don't want to deal with derailleurs anymore, although I might leave the one up front.
For a motor and battery, I was planning on the Double Gear / Double Torque with the 52V Mighty Mini 30Q with the motor on the front wheel and battery in the back (perhaps on the seat post but not married to that idea). https://lunacycle.com/double-gear-double-torque-motor/
Custom options would be the DM24 700c rim, Luna twist throttle, torque arm, and 300W charger.
Am I on the right track here, or will I run into unforeseen problems with this build?
Budget: ~$1,200
